Old 06-30-2009, 05:43 PM   #1 (permalink)
nesto's Avatar
drill out ford rims
i got a great deal on some 20"rims on some 37 mud graplers i love the rims but they came off a 99 ford and ive heard of just drilling out the holes and you will be able to fit them but if anyone can throw me some tips
99 with some stuff here and there nothing major
nesto is offline   Reply With Quote
Old 06-30-2009, 05:46 PM   #2 (permalink)
8UPRACIN's Avatar
DONT DO IT! you will have vibrations problems and the fear of loose wheels!! Sell the wheels and get the correct bolt pattern. You'll have nothing but problems and most tires shops won't touch a well that has been drilled due to liability issues
CHRIS 2001,6SPD,South Bend 3600DD,B-D Short Shifter,EDGE,SMARTY,MACH 7's,Custom HTB2/ S475,JGS 50mm External,Water/Meth,FASS 150,A1's.Thanks to http://sourceautomotive.biz ,Siskiyou Muffler&Diesel, http://jgsturbo.com ,Tom&Gigs http://photobucket.com/8UPRACING
8UPRACIN is offline   Reply With Quote
Old 06-30-2009, 05:48 PM   #3 (permalink)
Dumbass
SmokinTheHippies's Avatar
do not do that !! it works in theory, but the very idea of loose wheels on the studs should scare you. such a not good plan amigo.
Originally Posted by SmokintheHerpies
i'm like the gift that keeps on giving.....to cummins forum.
SmokinTheHippies is offline   Reply With Quote
Old 06-30-2009, 05:49 PM   #4 (permalink)
nesto's Avatar
even after re balancing
Old 06-30-2009, 05:54 PM   #5 (permalink)
Dumbass
re balancing has nothing to do with the fact that there isnt a tight mounting surface from the rim to lugs.
PM NCummins on here, he works at a tire shop (as do a lot of guys on here) get his opinion. tell him i told you to ask him. see what he says...
Old 06-30-2009, 05:57 PM   #6 (permalink)
nesto's Avatar
alright thnx
Old 06-30-2009, 11:17 PM   #7 (permalink)
Just Another Cummins's Avatar
I work at a tires plus, and we wouldn't touch a wheel like that, we would tell you to put them on yourself lol
it is quite unsafe, we won't even touch wheels that have had completely new holes drilled, and what you would have to do is oval out the ford pattern holes
I don't even like putting on those cragars that have oval holes and use washers to hold the wheel on lol
Cameron
01 QC SB 47RE
Tinted WS and all others, Raptor 150-DSV, 4" MBRP, 265s, soon to be more
2590.8 MM Western Straight Blade
RU "Sirius"
Just Another Cummins is offline   Reply With Quote
Old 06-30-2009, 11:52 PM   #8 (permalink)
I love Crappy Patties!!!
SkinInc69's Avatar
If you must use those wheels and tires then get some wheel spacers/adapters(our bolt pattern to fords pattern). They will be about 1.5"s thicks so they will stick the wheels out farther but it will be safer then drilling them out. Your best best and safest bet is still to sell them and get the correct wheels.
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance BLACK MAXX, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
Old 07-01-2009, 08:25 AM   #9 (permalink)
gotacummins's Avatar
x2
just search wheel adapters on ebay or yahoo and youll find plenty that will work. Wheel adapters are safe. Our bolt pattern is 8X6.5
BTW I thought 99 fords were the same as ours??
Lug Nuts Wheel Adapters Spacers Lug Bolts
"If JESUS bore the cross and died on it for me, ought I not to be willing to take it up for Him?" 93 D250 club cab AT HE351CW, 4" DP and custom exhaust ,cooler tubz, Denny T pin, 3200k spring, BLK H2's
gotacummins is offline   Reply With Quote
Old 07-01-2009, 09:18 AM   #10 (permalink)
Dumbass
Originally Posted by gotacummins View Post
x2
nope, 99 is the first year of the superduty, and thats the year they switched, all of the old body styles will fit.
i agree with the wheel adapters being a good alternative to selling.
