Old 06-29-2009, 01:47 PM   #1 (permalink)
sstuck2's Avatar
Clearing 38x15.50r20's w/ 6" Superlift
The tires are 38x15.50 Dick Cepek FC-II's mounted on 20x9" wide wheels with 4.5" backspacing. Bumper is shimmed out with 4 washers on bottom bolts and 5 washers on top bolts. This is a must or they will probably rub your bumper. Some plastic trimming. Also some optional metal trimming/bending on corner of fender behind tires. Let me know what you think.
Drivers side @ closest points
Passenger side @ closest points
Full shot
Difference between 35 and 38
Rear view
Before
After
Duals
07 2500 4x4, 6.7 auto, Pioneer Navi, factory remote start, XRT, Edge HOT, Airaid Intake, H&S 5" tbe w/6" tip, egr delete, leveled, 35" FC-II's on custom 20" DC-1's
sstuck2 is offline   Reply With Quote
Old 06-29-2009, 03:18 PM   #2 (permalink)
Northern CA Chapter President
Neel's Avatar
looks way better man. thats how i got my 41's on 20x12 wheels to fit
2006 cummins 3500 laramie murdered out
13.5'' lift, 20x12's on 41'' iroks
www.AllOutDiesel.com
TURBO ENGINEERING CORP. 617hp, stock cp3,stock lift pump, and on 41's
custom paint and amp step getting done
Neel is offline   Reply With Quote
Old 06-30-2009, 04:23 PM   #3 (permalink)
Do you have adjustable control arms on your lift
GEN_X is offline   Reply With Quote
Old 07-01-2009, 05:53 PM   #4 (permalink)
sstuck2's Avatar
Negative ghostrider, not at the moment
Old 07-02-2009, 08:04 PM   #5 (permalink)
PUREVIL's Avatar
I read in your other thread you were getting a 2.5 inch spacer for the front... is that installed in these pics? Looks good, im thinking about getting 8 inch coils so I was curious how bad its rubbing with a 2.5 spacer since it would be a .5 difference.
2005 Ram 2500, MP8, Smarty, FBD 5in TBE, AFE, 20inch RBP 91R w/ 37in. Mud Grapplers, Tint, Custom Wrap, 4.56 Gears + Yukon Locker, 8in Lift, Banks Technicooler, Air Dog 150, AMP Steps, ARP, Arson III, II Dual CP3, BD Turbo Guard, DDP 120s, II Silver Bullet 66
PUREVIL is offline   Reply With Quote
Old 07-04-2009, 01:19 PM   #6 (permalink)
sstuck2's Avatar
negative again, the spacer is not installed, and they only rub if i have the wheel turned all the way and really flex the suspension
