Old 06-22-2009, 12:00 AM   #1 (permalink)
cummins freak
seeingred's Avatar
tire and rim ?
i found a set of rims i really like only problem is 9in. is a narrow as they go will the stock 265/70/17 fit and look good on a 9 in wide rim? want to stay stock tire size cause i pull my gooseneck all the time. thanks
07 mega cab 5.9 g56 6spd 2500 4x4 S&B intake diamond eye 4 inch turbo back duals with mbrp black tips
"Smokin with no power is about like carrying an unloaded pistol on your hip everywhere you go. " jmd025
seeingred is offline   Reply With Quote
Old 06-22-2009, 12:18 AM   #2 (permalink)
cummins freak
seeingred's Avatar
these are the ones i am thinking about Teflon Chamber 17x9 8/6.5
Old 06-22-2009, 03:33 PM   #3 (permalink)
I looked on Tire Rack to see what they recommend for that size tire and at least for the tire shown 9" is at the upper end of recommended.
Tire Specs for Goodyear Wrangler AT/S
I don't think the link worked right; but if you go to tirerack.com and input the size tire you want and pick the tire you want and click on specs it should tell you what size rim will work.
1996 3500 4x4 SLT extended cab 5 speed with 4.10:1 and Gear Vendor Splitter and airbag suspension, pyrometer and boost gauges.
heinlein is offline   Reply With Quote
Old 06-23-2009, 02:02 AM   #4 (permalink)
cummins freak
seeingred's Avatar
thanks for finding that for me
Old 06-23-2009, 03:30 PM   #5 (permalink)
Many of the posts I've read have answered questions for me. If I can help someone else it sees like the right thing to do.
