Old 06-21-2009, 11:16 AM   #1 (permalink)
mbshooter's Avatar
mpg loss?
approx how much mpg will i lose if i go to 35's from stock. the lift would be the carli starter system.
2005 - 3500 SRW 4wd, 5" farmboys exhaust, AFE stg 2, Smarty, 5" wicked Lift, 37" procomp xtreme AT'S, Gear Alloy Injectors
IBEW 915
mbshooter is offline   Reply With Quote
Old 06-21-2009, 11:17 AM   #2 (permalink)
cmns2500's Avatar
if you have the 4.10 gears, you'll gain a lil bit on the high way, if you have 3.55's, you'll lose a lil on the hi way, and lose a chit ton in town...
CJ's truck....CLICK HERE===>>join CF TRUCKIN' on Trukz.com
02 5 speed/stock ish... w/ a Scan Gauge II monitorin stuff... TCW3 Two Stroke lubin er up...
Old 06-21-2009, 11:22 AM   #3 (permalink)
mbshooter's Avatar
i have 4:10's
IBEW 915
Old 06-21-2009, 12:08 PM   #4 (permalink)
cmns2500's Avatar
the 35's will bump it up higher(lower number), so, you'll get a lil bit better fuel mileage...
and, these trucks look better w/ 35's anyway...
Old 06-21-2009, 12:58 PM   #5 (permalink)
BlackedOut02's Avatar
i have 35x12.50x17's with 3.55's and have gotten 20+ mpg my last 3-4 tanks. i do mostly mixed city/highway driving (with a few rips).
'02 | 2WD | 2500 | NV4500
"Diesels dont run away. Diesels over speed, mechanics run away"
BlackedOut02 is online now   Reply With Quote
Old 06-21-2009, 09:07 PM   #6 (permalink)
mbshooter's Avatar
hmmm, about how much should i expect to pick up?
IBEW 915
Old 06-21-2009, 09:13 PM   #7 (permalink)
A couple on the highway. None in town.
2004.5, 2500, Cummins 600, 4x4, SLT, QC, SB, 4.10's, 315's, Molten Red. 48RE built by HTS . BullyDog Crazy Larry stacked w MP-8, AFE PG7 and Blade Runner, Silverline 4" to 6" mitre, DiPricol trans and fuel, Train Horns for
JDiepstra is offline   Reply With Quote
Old 06-21-2009, 09:24 PM   #8 (permalink)
2500redram's Avatar
I lost about 2 with 285s but i got 3.55s. just remember your rollining resistance is greater so you will prob. lose mileage.
01 2500 4x4,2" leveling kit,edge drag comp,4" TBE w/5" tip,BHAF,ats arcflow,silencer ring, muffler MIA,trans/boost/pyro,,nv4500,Valair 13"kevlar/ceramic clutch,bd short shifter,fass 150,Coaltrain 150s,Bigstick cam,studs,110 springs,push tubes,
2500redram is offline   Reply With Quote
Old 06-25-2009, 05:37 PM   #9 (permalink)
Sasquatch
crazyrunner33's Avatar
I switched to 285s and the truck is now a full second slower 0 to 60.
'99 Cummins: too many mods to list
Some tips on using the search function for better results.
crazyrunner33 is offline   Reply With Quote
Old 06-26-2009, 03:04 AM   #10 (permalink)
I have exactly that setup and easily lost 3 mpg. More weight =more power/gas to get em movin. Bought Smarty Jr to hope to make up diff. Definitly made up power loss yet to calc to see if made up mpg. Not sure how you gain mpg.
titan0454 is offline   Reply With Quote
