Old 06-21-2009, 08:38 AM   #1 (permalink)
gotacummins's Avatar
Whats the best way to remove the H2 lip???
I know alot of you guys run the h2 wheels, whats the best way to remove the lip yourself?
thanks
"If JESUS bore the cross and died on it for me, ought I not to be willing to take it up for Him?" 93 D250 club cab AT HE351CW, 4" DP and custom exhaust ,cooler tubz, Denny T pin, 3200k spring, BLK H2's
gotacummins is offline   Reply With Quote
Old 06-21-2009, 12:49 PM   #2 (permalink)
BlackedOut02's Avatar
die grinder take it easy though, that metal is soft.
'02 | 2WD | 2500 | NV4500
"Diesels dont run away. Diesels over speed, mechanics run away"
BlackedOut02 is offline   Reply With Quote
Old 06-21-2009, 03:07 PM   #3 (permalink)
John's Truck's Avatar
Use a router and a bit with a roller guide. Flip the wheel over and use the flat surface for the router. The roller guide should be just below the lip, on the 2nd, wider surface area. Took about 1 min per wheel. I had to buy a router, so the whole operation ran me about 90$. Obviously if you own or borrow a router, it's free/cheaper.
04.5 2500 CTD CC Shorty 4x4... K&N intake, Silencer ring removed, Muffler delete pipe
John's Truck is offline   Reply With Quote
