Old 06-13-2009, 10:41 PM   #1 (permalink)
Texas Trophy Trucks
meadh8's Avatar
BFG AT load range question
so the 305/70/17 BFG AT is load range E at 3195 lbs @ 65 psi, the 315/75/17 (my preferred larger tire choice) is load range E at 3195 lbs also, but it is at 50 psi. what is the difference here besides tire size, max psi, and max load?
should i run the slightly smaller 305's b/c they can run a higher psi and likely take weight better and allow for better mileage because it will be more stiff at 65 psi? or is the 315 tire only required to run 50psi max because it has a higher tread area to distribute the vehicle's weight?
'07 6.7L 2500 SB 4x4 4"TBE XRTHD175ATTFASS 150ISSPRO EV2's
14.50 @ 94.2mph 1/4
Texas Trophy Trucks
918-520-2669 or 713-249-6049
meadh8 is offline   Reply With Quote
Old 06-15-2009, 06:39 AM   #2 (permalink)
The load rating is on max psi so a E=80psi and one tire can support 3042 lbs a load range D=65psi tire will support 2535lbs,,a load range C=50psi tire will support 1875lbs per tire.
This is a cross section on tires as the size changes the loadlbs changes.
A lower load range tire will ride better if you can get it in your size.
The 245/57/16 BFG AT only comes in a load range E so I
had no choice,,and almost all tires in that size is a E.
Jack Johnson
jackjo789 is offline   Reply With Quote
Old 06-15-2009, 11:29 AM   #3 (permalink)
surfram's Avatar
The 305/65/17 BFG AT KOs are E-rated but the max air pressure is 65psi. The 315/70/17 BFG AT KOs are D-rated with a max pressure of 50psi. Both tires have the same max weight rating of 3,195lbs. I got 58,000 miles out of my last set of 285/70/17 D-rated BFG AT KOs with no problems towing or hauling heavy. BFG now makes an E-rated 285/70/17 AT KO that has a max pressure of 80psi. I am currently running the E-rated 305/65/17 AT KOs. The 305s are the same height as my old 285s(spare tire is a 285) but just as wide as 315s. Here are the BFG specs:
BFGoodrich Tires | All-Terrain T/AŽ KO | Tire Sizes & Specs
305/65/17 BFG AT KO on my truck:
2004 2500 SLT SWB 4x4,305/555, in-tank lift pump, 48RE, 3.73, westin cps step bars, magnaflow pro 4" TB, 305/65/17 BFG AT KOs,Timbrens, Leer Cap, Firestick CB antenna mounts, Wilson Silverload 5' antenna, Uniden PC78LTW CB
surfram is offline   Reply With Quote
Old 06-15-2009, 11:46 AM   #4 (permalink)
joelc79's Avatar
Don't waste your money on load range D. They will wear alot faster
03 1TON currently broken
joelc79 is offline   Reply With Quote
