![]() Join Date: Aug 2007
I've been trying to learn about the tire ratings. Never worried about it back when I drove a 1/2 ton pickup. I like to think I can tow whatever I want, but in reality I have a 18' steel car trailer and a Jeep YJ Wrangler that I will tow once in a while to go play. That's about it. My trailer will only hold so much, so prob not going to see any huge loads. I've been looking at tires online and I have tried to look only at E rated tires. I want to get a larger size like 305 or 315, but most I find are D tires. What do ya think??? Do I need E rated?
2004 Crew Cab 4x4, 305 5.9L, K&N intake system, Banks exhaust system. Hankook MT 265/70-17 First diesel, so still learning |
#2 (permalink) |
Skrew- EPA CARB OPEC PETA
![]() Join Date: Mar 2007
I think you'd be fine with D. if you were to tow more than 10K thats when E comes into play (for me anyway) ...others may have different input.
2004.5, QC, LB, Crapomatic, 4x4 Factory Nav. AirDog 100, Arson Kit, AEM Bruteforce HD, Silverline 5" t409, BMK-11, Mag-Hytec, Bilstein 7100, B&W, Tekonsha P3,DiPricol's HMX-1 Executive Flight Detachment Avionics Technician ![]() |
#3 (permalink) |
I've ran D rated tires towing my 10k trailer many times and they did great. Make sure the load rating is up to par and you should be fine. since D rated tires have move flexable sidewalls it makes for a more comfortable street ride than E rated. The stiffer sidewalls on E rated tires do help when towing heavy and getting more tread life.
2007.5 w/ 6.7l, auto, XRT 175hp, Suspended by Carli Bilstein 2.65'' and some Carli extras Class 7 Prerunner 520HP Ford, equal length i-beams/3 link w/ King Coilovers/Bypasses/bumps |
#4 (permalink) |
i run d rated tires on my truck all the time. never had any problems ever with them
2005 white 2500, bully dog power pup with outlook with crazy larry!!,bully dog rapid flow cold air intake, silencer ring M.I.A, FBD 5" TBE/ 6" tip , 35 in cooper S/Ts |
#5 (permalink) |
I tow heavier stuff so I run E. I just play with the air pressure to get the ride I want when I am not towing. They seem to hold up better and last longer. I don't wheel, but I'm on gravel and loggin roads a lot while hunting and I seem to have less problems with flats and sidewall tears. Even if you run D's air pressure is huge when you are towing. On taller tires I like E because the side walls don't flex as much when they are air'd up to full pressure when I'm towing.
04.5 Qd CB 4X4 AT, Super "B" Special, 'Pusher' int horn, PacBrake, Edge w/Att, S&B Cool air, 4" MBRP, 35 Toyo MT's, air bags, spr hitch, B&W gooseneck hitch, BD Trani parts, guages, lock up switch, smoke switch, horn blstrs |
#6 (permalink) |
unless you haul heavy loads, and especially heavy loads right on top of the rear axle (5th wheel or just something heavy as heck in the bed) you'll be fine. i'm not certain of the 3rd gen stock wheel size, but 315/75/16's are E rated in BFG A/T's and M/T's. so as long as you have an 8inch wide wheel you can run either of those, have the hauling potential you need and the wear and off road performance you want. if i remember correctly the toyo m/t's are the same way.
Present: 1998.5 2500 24v Club Cab swb 4x4. Past: 1997 2500 12valve club cab lwb 2wd. Bought new, 240k before trading in. |
