Old 06-11-2009, 09:21 PM   #1 (permalink)
dlevey's Avatar
06 Tire eater
Can't tell you how many sets of tires I put on this truck with 60,000 on it. The backs wear fast and the fronts cup.
Replaced ball joints 2000 miles ago. Ready to sell the truck.
Best wearing tires please?? I will go back to stock 265 70 17.
2006 CTD Level kit with 315 Goodyear Wrangler Extreme A/T Pred+Puck Boost fooler, 5'' Turbo back exhaust, EDGE Insight, 6" high volume intake
dlevey is offline   Reply With Quote
Old 06-11-2009, 09:24 PM   #2 (permalink)
Black Smoke Addict
RedRum's Avatar
do you rotate them? You may get a little more out of them. What psi?
2007 3500 QCLB, 5.9, ISSPRO, AFE Stage 2, AF1 intake horn, Smarty, SB 3600#, Straight Piped with 6" Mitres, 6" lift, Bilstein 5100s/dual steering stabs., trac bars 37" BFG M/Ts, CUMMINS FORUM STICKER!May 2009 ROTM-Thanks to James @ RSD for stepping up!
2006 3500 QC Bighorn, 6 speed, No silencer ring, B&W turnover, other than that, stock
"I Caught that diesel thing, now it stings when I pee"
RedRum is offline   Reply With Quote
Old 06-11-2009, 10:15 PM   #3 (permalink)
MI Chapter President
IC-Smoke's Avatar
I pull a trailer a lot and the rears seem to wear quicker, even when rotating every 5K miles
keep them rotated, make sure its aligned up front and your ball joints are good
IAN COLEMAN - President Great Lakes CUMMINS Crew
1990 W350 4x4 LE std cab auto Project Restoration
2001 2500 4x4 3rd gen head, Twin Turbo, DTT trans, Monster pump
2006 2500 4x4 Smarty JR, H2's, B&W, AFE, 5" exhaust, meyer plow
IC-Smoke is offline   Reply With Quote
Old 06-11-2009, 11:55 PM   #4 (permalink)
I've run Goodyear tires in the past and had nothing but trouble. I have had wrangler at/s and wrangler at, both sucked. I will not buy wrangler tires for a heavy truck ever again. They all seem to have a soft compound. I have been running Nitto Terra Grapplers for 80,000 miles (two sets) and just ordered a new set of 285/75/17 grapplers today. I also am getting ready to order some Kumho mud tires for the 16" stock rims for hunting season. Oh yeah, make sure you are running load E tires.
02 QC LB, 4x4, ISSPRO gauges, garmonized trans, triple disk, hot rod vp44, dragon flow sticks, Garrett GT3782R, aem workhorse intake, 4:10, 4" silverline, BD RAD, comp as ez, smarty, raptor 150, 285/75/17 nittos, nav, dvd, twin 15" subs, 7.1 surround sound.
jesnic is offline   Reply With Quote
Old 06-13-2009, 06:20 PM   #5 (permalink)
oldsmobiledave's Avatar
Duravis & M-55
as I posted in another thread the Bridgestone Duravis line & the Toyo M-55 are tough long lasting tires capeable of anything you can throw at them
2004.5 Quad Cab 2500 4x4 auto VA C3.2 Carli Suspension
2005 Reg Cab 1 Ton Dually 4x4 auto Smarty Powered
Finding Oil & Burning Diesel
oldsmobiledave is offline   Reply With Quote
Old 06-13-2009, 06:34 PM   #6 (permalink)
lake huron cummins's Avatar
My truck ate a set of 17" Toyo's in 14k. The tire shop said they were the flatest, most even wore tires they had ever seen and were absolutely floored when I told them they had 14k on them. I switched to Nitto Terra Grapplers and chewed them off in 9k. Burnouts, you may ask?? None. Load range?? E. Tire pressure?? 65-70 and the sides are wore the same as the center. I switched back to 16" wheels and grab the best tires out of the pile of junkers out machanic is throwing away from our company trucks. If I burn off a set in 5k, who cares!! They are free!!! I just go and get another pair. I keep the 17" Nitto's for the winter. I am currently running 235/75/16 Firestone Transforce. They are awful in the rain but they leave really long marks in the road!!!
99 2500 q/c 4x4, 4" Silverline exhaust, Edge Comp Hot Unlock, 150hp sticks, HTT 62/71/13, 150 GPH FASS, Suncoast triple disc tc & vb, Mag-Hytec dbl deep pan, AFE Stage 2, 06 17" w/265 Nitto Terra Grapplers, A-Meter Ultra Lite pyro, boost, trans gauge.
lake huron cummins is offline   Reply With Quote
Old 06-14-2009, 03:17 AM   #7 (permalink)
MOTONATE's Avatar
How is that even possible? Ive had my toyos for 9k now, and they still are looking great. I run 50 PSI and rotate every 4k..........
2006 QC Bully Dog PMT, Thuren suspension, 35x12.50x20 Toyo MT's on American Racing wheels
68' GTO BB400 matching numbers and way too many mods to list.......
MOTONATE is offline   Reply With Quote
Old 06-18-2009, 04:56 PM   #8 (permalink)
Beats me!! I've heard from others who have had good luck with both Toyo's and Nitto's. The only difference is they don't live in Michigan. Our roads up here absolutely suck. I-69 between Port Huron and Flint will rattle the fillings out of your teeth and the rest of our roads are even worse!! It's the only thing I can figure.
Old 06-18-2009, 09:46 PM   #9 (permalink)
Try the Nitto Dura Grappler. I just purchased a set and they are suppose to be the best wearing HD tire currently available.
06' 2500 QC, short box, 4x4, Edge with Attitude, AFE stage II, muffler delete, Nitto 285/75 17 Dura Grapplers
Nichols92 is offline   Reply With Quote
