Old 06-01-2009, 12:49 PM   #1 (permalink)
06 Cummins
Mattlosch's Avatar
37'' issues
truck is a 2006 with 2'' revtec leveling kit.. currently running 355/70/17 toyo at's on h2's.. they rub the back of the fender pretty often, toyo claims they are 37-14-17.. my question if i get some 37-12.5-17'' tires like goodyears mtr's, yok's at's or mt's, something narrower than my toyo's, will they rub still you think??
2006 QCSB, G56, 5.9L, Smarty TNT, Valair3600DD , ISSPRO EV2's, REVTEK, 37'' BFG KM2, SRT8 side piped, murder'd out
477hp 1092tq
13.98 @ 97mph
on 37's 2nd gear non boosted launch 4wd
www.Sourceautomotive.biz
Mattlosch is offline   Reply With Quote
Old 06-01-2009, 02:08 PM   #2 (permalink)
Blackdodge2008's Avatar
that has got to rub alot, I have a 08 with the revtek level kit and I run 34" tires and I rub, I can't even imagine running 37" with out a lift.
2008 3500 4X4 QC Black Pearlcoat / 6 speed Auto / AFE stage 2 intake / 2" leveling kit / 20" Jesse James Lawless 8/ 305/60/R20 Toyo Open Country A/T / Bushwacker Pocket Flares/ EGR Unplugged
Blackdodge2008 is offline   Reply With Quote
Old 06-01-2009, 02:44 PM   #3 (permalink)
btolenti's Avatar
There was a post about a guy running 37's on H2's with no lift....so I assume if you went to a narrower 37" tire, you would be okay. As always, backspacing is the key, and the H2 rims are your best shot at getting 37's to fit properly.
I would assume your rims are a 4.5" backspace, Blackdodge2008?
06 Silver Quad Cab 4x4 Automatic
-4" Rancho Lift w/Superlift Traction Bars & Defiant Steering Support, 315 MTZ's on H2's
-Smarty, AFE Intake, Muffler Delete, Airdog100/Liberty Setup, ISSPRO Gauges, Amsoil BMK-11
btolenti is online now   Reply With Quote
Old 06-01-2009, 02:59 PM   #4 (permalink)
they are a +12, so what ever that is. lol
Old 06-01-2009, 05:47 PM   #5 (permalink)
06 Cummins
Mattlosch's Avatar
it rubs quiet i bit but i think thats alot because they measure out 14'' wide.....
477hp 1092tq
13.98 @ 97mph
Old 06-01-2009, 06:11 PM   #6 (permalink)
ban89's Avatar
The way most of us are getting away with running 37'' tires on small lifts are bc of the Carli extended control arms. They push the tire away from the cab so it doesnt rub but they are also offest to the inside so the tire doesnt rub on the upper arm.
I also run the stock wheels to fit 37'' tires because of the following specs. (thanks mattingly)
The OEM forged and polished aluminum wheels have the following dimensions:
Offset: 43.18mm (1.700") positive
Backspace: 6.25"
Hummer H2 wheels have the following dimensions:
Offset: 18mm (0.709") positive
Backspace: 5.563"
The wider the wheel and the less BS the greater chance you will rub on the cab. The more BS the greater chance you will rub on the control arms at full lock.
The Yokos are smaller and narrower and lighter than most 37'' so they should fit easier.
2007.5 w/ 6.7l, auto, XRT 175hp, Suspended by Carli Bilstein 2.65'' and some Carli extras
Class 7 Prerunner 520HP Ford, equal length i-beams/3 link w/ King Coilovers/Bypasses/bumps
ban89 is offline   Reply With Quote
Old 06-01-2009, 06:13 PM   #7 (permalink)
06 Cummins
Mattlosch's Avatar
thats some really good info... thanks!! maybe i might have to settle for some 35's for now...
477hp 1092tq
13.98 @ 97mph
Old 06-01-2009, 06:42 PM   #8 (permalink)
jetfuel394's Avatar
LIFT IT UP!!! DONT SETTLE 4NOTHING U DON'T WANT!!!
04.5 2500 Q/C edge hot juice w/att. 100hp sticks rips billet trans,a/d150,stg1cp3 s/ 64turbo w/5"t/back straight pipe,afe cai,8" lift,37 coopers on helo wheels,traction bars,s/s st.support,nav/vid w/surround. thx to rip at source diesel.
jetfuel394 is offline   Reply With Quote
Old 06-01-2009, 07:38 PM   #9 (permalink)
06 Cummins
Mattlosch's Avatar
i dont want to lift it though.. i am eventually going to be running a carli kit so i dont wanna spend any money on suspension right now...........
477hp 1092tq
13.98 @ 97mph
Old 06-01-2009, 07:49 PM   #10 (permalink)
jetfuel394's Avatar
i seeeee! ok! btw the vid by psu was awesome!!
Old 06-01-2009, 07:54 PM   #11 (permalink)
06 Cummins
Mattlosch's Avatar
hahaha yeah that was fun!!!
477hp 1092tq
13.98 @ 97mph
Old 06-01-2009, 08:17 PM   #12 (permalink)
Travis A's Avatar
how much did u pay for the 355/70/17? do you remember. right now i am 8'6" wide from outside tire to outside tire, i plan on getting a 8.5" lift kit and i want to hit 9' wide (i like a big rear end) and 14" wide tires should easily put me there.
early 04 dodge ram dually auto mods: Full billet DTT tranny, Edge J w/ A, Smarty beta 4.2, AFE stage 2, S&B Intake horn, remote starter, turbo timer, train horn, dipricol Trans, fuel, and rail. silencer ring MIA.
Travis A is offline   Reply With Quote
