Old 07-04-2009, 02:23 PM   #25 (permalink)
hamel1's Avatar
I have Nitto Terra Grapplers right now. Last one's were Perrelli ATR. Perrelli's worked great in all weather but as they wear down they start to slip. The Nitto's so far have been good but I've had them a month. The size is 305/70/17 and they look great. Hope this helps
2005 Dodge Ram 2500 2.5" leveling kit Bilstein Shocks Alien Patrol bumper Piaa 510 (4) hids?
hamel1 is offline   Reply With Quote
Old 07-04-2009, 03:41 PM   #26 (permalink)
mbshooter's Avatar
do at's get better mpg than mt's. also why would the atz's last longer than mtz's?
2005 - 3500 SRW 4wd, 5" farmboys exhaust, AFE stg 2, Smarty, 5" wicked Lift, 37" procomp xtreme AT'S, Gear Alloy Injectors
IBEW 915
mbshooter is offline   Reply With Quote
Old 07-04-2009, 04:14 PM   #27 (permalink)
Mad Scientist
icemanjc1's Avatar
I would guess MPG's would be the same. More tread contacting the ground would make the ATZ last longer. That's only my guess, I've never ran MTZ's.
-2006 QC Laramie 4x4 Auto w/ billet flexplate, Goerend Triple TC and Transgo, Smarty Revo, S&B, A3k, ATS manifold, Aero 4040XL, KORE springs and Thuren stuff, 35x12.5 Toyo M/T.
-95' Ford F250 4x4 w/ 2001 P-pumped Cummins, 5speed ZF, 100hp jammers, helix2 cam, sportsman springs, S300, front coil/4 link conversion, 35" Mickey Baja ATZ.
icemanjc1 is offline   Reply With Quote
Old 07-04-2009, 06:21 PM   #28 (permalink)
mbshooter's Avatar
what about the yokohama's and cooper stt's? seems like everyone has been raving about them recently?
if it makes a difference i need a quiet tire. drive alot between 70-80mph and need to be able to hear.
IBEW 915
Old 07-05-2009, 12:52 AM   #29 (permalink)
Megaram's Avatar
Mickey Thompson Baja ATZ Tire Test
One of the latest "new-generation" MTs
By Jimmy Nylund
Photography by Jimmy Nylund
At first we were a bit concerned when Mickey Thompson Performance Tires & Wheels became part of the far larger Cooper Tires, the eighth largest (in sales) tire company in the U.S. for the past few years. So much for seeing any more small-volume enthusiast tires, we thought. Luckily, we were completely wrong, and Mickey Thompson keeps cranking out specialty tires-except of much better quality.
In the case of the Baja ATZ, small volume only refers to the relatively small numbers of tires made (compared to the enormous amounts of passenger-car tires sold in the U.S.), as the smallest ATZ at this writing was a 33x15.50R15. That may not sound all that large, but this was the first 33-incher that rubbed the fenders of our test Blazer-which normally allows 35s to fit comfortably.
With a section width of 15.7 inches and a tread 12.1 inches wide, the 15x10-inch Classic Lock II wheels we used are technically too narrow for the tire, but handling was still very good, and the tracking we had anticipated was practically nonexistent. Besides, with 12-inch rims the tires would've really rubbed. There was more tire noise than expected, but the ATZ is by no means a loud tire. It's just that with four patches over a foot wide each, there are a lot of tread blocks hitting the ground at once, and it's enough to be audible. Yet the rolling resistance was relatively low.
With a high load-carrying capability (2,405 pounds at 35 psi) and a nylon cap over two steel belts, the tire still soaks up irregularities in the road pretty well, and made in a 12-segment mold, it runs very true and smooth. On the Hunter GSP 9700 balancer, we saw very low Road Force Variation numbers (8, 15, 12, and 14 pounds), which is especially impressive on a wide tire weighing 83 pounds. This says a lot about the build quality of the tire, and the trueness of the Classic Lock II wheels. Those 'locks, by the way, are a purely cosmetic add-on, but since they're available separately, they can be used as sacrificial rim edges. The wheels themselves are guaranteed against structural defects and have steel inserts for the lug nuts to spread the clamping load through.
We expected the 12.1-inch-wide tread to do pretty well in sand, and it did. However, airing down to a conservative 10 psi apparently made the stiff-treaded radial push so much sand ahead of itself that we aired back up again-the price you sometimes pay for running a radial with good road manners. In harder dirt, a lower pressure allows the Sidebiter lugs on the sidewall to help with traction, and conformability improved to the point that fist-sized rocks were barely noticeable.
Great for traversing ruts, the width of the ATZ works for or against you, depending on the situation on hand, and the vehicle. Our portly test vehicle put enough contact pressure on the relatively mild tread to make it work in the dirt, but on a lighter rig, the more aggressive MTZ would be a better choice. The same would hold true for mud, of course, but we didn't have any to try the ATZs in.
We feel that the Mickey Thompson ATZ is a tire primarily for the street that works well on the trail under a heavier vehicle, but between the stiff tread area (which makes it perform on pavement) and it being a radial, it's not something we'd put on a trail-only vehicle. Now, if you'll excuse us, we'll go cut some more sheetmetal off the fenders on our mostly-street four-by so that these tires won't rub as often.
Tire: Mickey Thompson Baja ATZ
Type: Radial
Load range: C
Max load (lb. @ psi): 2,405 @ 35
Sidewall: Three-ply polyester
Tread: Three-ply polyester, two-ply steel, one-ply nylon
Approved rim (in.): 11-13
Tread depth (in.): 20.5/32
Tread width (in.): 12.1
Section width (in.): 15.7
Overall diameter (in.): 32.9
Static loaded radius (in.): N/A
Revs per mile: N/A
Weight (lb.): 83
Test vehicle/weight (lb.): K-5 Blazer/6,300
06 Mega 3500 CTD 48RE, 4:10's,Banks CAI, High Ram, Exhaust, Kore Chase With Fox Set Up , Adj. Track bar, Steering Damper, Ranch Hand Steps, Line-X, Randy Ellis Light Bar, Mickey Thompson ATZ 35 Dale Earnhardt Jr. Cannon, MP-8 & quadzilla RPG, Smarty Jr.
Megaram is offline   Reply With Quote
Old 07-05-2009, 11:08 AM   #30 (permalink)
mbshooter's Avatar
good read. in one of the recent 8 lug magazines there was an artcle on the mtz. they really praised that tire as well. mickey thompson has always done really well. i am just more curious how many miles people are getting out of them with our heavy trucks.
IBEW 915
