Old 04-20-2009, 07:30 PM   #1 (permalink)
New Cummins dually owner & need tire advice...
Ok, as of 2 days ago I joined the Cummins family. I just picked up a 2003 DRW 4x4 and it is gonna need tires pretty soon. I want to step up to a taller tire than the 235/80/17's that are on her, but don't know what is gonna fit. What is the biggest I can go? Also, what size would ya'll recommend?
'03 3500 H.D., 6spd, 4x4, Dually, Quad Cab, juice w/ attitude, D.I.Y. BHAF intake, straight pipe
jmccall is offline   Reply With Quote
Old 04-20-2009, 08:15 PM   #2 (permalink)
Banned
Good luck finding something taller that will work on the stock wheels and not be to wide for the rear duals.
I have been looking for the last week with no luck.
I did finally find something I am going to try to make work with the use of rear spacers.
285-75-17 load range E.
I will let you know if it works out as I ordered them today.
DWRAT is offline   Reply With Quote
Old 04-20-2009, 08:21 PM   #3 (permalink)
thanks, i have been to every tire place in my area with no luck. I don't really want to go to an extreme on height, just a little bigger. i looked at spacers, but my problem is i am in the army and live in the barraks where nobody can park, so if i don't want to go too much wider in the back otherwise i won't fit in the parking spaces. and taking up 2 spaces is a no go because the mp's here will ticket and tow you in a heart beat. well, the search will have to go on for now.
Old 04-20-2009, 08:28 PM   #4 (permalink)
Over Fueled and Budget
Magic smoke's Avatar
265/70/17's will fit without spacers.
Early 04 3500 drw quad cab-6speed- Valair DD- fast coolers - 4x4 -S&B -fass 150-expandit 5"- FTE resonator -SMARTY-autometer C2 full pillar gauges- di-pricol rpg-Dragonslayer cp3-64/71/14-PDI manifold -Wicked 125's - $2 rail cap.
Magic smoke is offline   Reply With Quote
Old 04-20-2009, 08:52 PM   #5 (permalink)
Banned
That size is shorted then the stockers.
Use this site to help with sizing up yor tires.
Tire Dimensions Made Simple - Discount Tire
Old 04-20-2009, 08:57 PM   #6 (permalink)
thanks dwrat, i knew i had seen that calculator someplace before. according to the calc the 265/75 is .42" taller on the side wall. i may go that size then, but still open to suggestions.
Old 04-20-2009, 09:24 PM   #7 (permalink)
Banned
I could not find any E rated tires in that size at all anywhere.
Make sure you get a E rated tire.
Old 04-20-2009, 09:30 PM   #8 (permalink)
yeah, i just realized the same thing. looking online right now. i think i may just go with 265/70's. found a few that are E rated.
Old 04-21-2009, 07:39 PM   #9 (permalink)
mdtouchet's Avatar
I have 35/10.50/17 Interco SSR’s on stock wheels with ¼” spacer between the rear wheels.
Silver 06 4x4 Mega Cab Dually, 5" TBE, 2" leveling kit, BFG KM 255/75/17, Top Gun front / Frontier Gear rear bumpers, Retrax bed cover, Amp Reserch Power Steps, http://profile.myspace.com/index.cfm...ndID=146489284
mdtouchet is offline   Reply With Quote
Old 04-21-2009, 10:00 PM   #10 (permalink)
Andrew Allen's Avatar
I got 295/70/17's on my truck... fit stock minus needing spacers.. but looks super good!! wide and tough lookin!!
: 2003 Dodge 6 Speed, "THE DUALLY" Smarty TNT/MP-8, Stage 1 CP3, FASS 150/150, 295/75/17 Terra Grapplers, 2nd Gen Manifold, Triple Gauges(Oil Temp, Boost, EGT), BUMPS under the back seat! 135 MPH TESTED! Soon to be the owner of a SBC Iron GIANT!
Andrew Allen is offline   Reply With Quote
Old 04-21-2009, 10:16 PM   #11 (permalink)
LT.
I think that you are going to run into the same problems the rest of us have. If you want to run a larger than stock tire you will need a rear spacer between the rear duals at least. Some tires may require you to run a spacer on the inside dual between the inside dual and the mounting surface.
LT.
2006 Dodge dually, QC, LB, 6 speed standard, Smarty, AFE stage II CAI, MBRP dual 4" exhaust, Quadzilla boost fooler, ATS Diesel intake manifold, 6" Superlift, 315/70/17 BFG AT's, South Bend Con FE clutch.
LT. is offline   Reply With Quote
Old 04-21-2009, 10:19 PM   #12 (permalink)
LT.
i got both, 1/2" inside and 2" between... looks SICK!!
