Banned
Dually rear wheels ???
I am trying to find wider and taller tires for the Dually but the rears are causing a problem. The only size tire I have found that is both taller and wider is a 285-75-17 but the rears almost touch with no load on them. Any advise out there??? Thanks Dan |
#3 (permalink) |
I run 315/70/17's on my dually with a two inch spacer between the rear duals. But, I must warn you that you need to be careful when choosing a tire especially if you run a lift with a rear block. Too wide of a tire can cause your inside rear duals to make contact with the rear leaf springs. This can be solved if you choose to run another spacer between the inside dual and the mounting surface. LT.
2006 Dodge dually, QC, LB, 6 speed standard, Smarty, AFE stage II CAI, MBRP dual 4" exhaust, Quadzilla boost fooler, ATS Diesel intake manifold, 6" Superlift, 315/70/17 BFG AT's, South Bend Con FE clutch. |
#4 (permalink) | |
03 Dually with Smarty W/ TNT, FASS 150/150, Stage 1 CP3, K&N, 6 speed W/ Prototype Single Disk Feramic Clutch, Boost Elbow, 2" leveling kit, 295/70/r17 Nitto Terra Grapplers, A-Pillar Triple Gauge pod |
