Old 04-12-2009, 11:00 PM   #1 (permalink)
farmboy876's Avatar
18x9 rockstars rubbing?
im looking to buy 18x9 rockstars on 35x12.50 mud grapplers, i already have a leveling kit will this setup fit?
07.5 3500 LB 6.7L, 2nd 68rfe, AFE Stage 2, TSP MP-8, Superchips F-Paq, H&S Stage 2 DPF Delete, K2 EGR & Cooler delete, Silencer Ring MIA, Zilla Fooler,2" leveling kit, 18x9 Motometal 951's, 35" Nitto Mud Grapplers DYNO= 446hp 860tq
farmboy876 is offline   Reply With Quote
Old 04-12-2009, 11:06 PM   #2 (permalink)
Shagginwagon's Avatar
Depends on the backspacing and offset of the wheel. Try to get close to 6" of BS and have a positive offset value.
'07 2500 5.9L Mega, Black, Laramie, 4X4, 48re
Isspro's, AFE Pro Dry, BMK-11, AMSOIL fluids, Debadged, CFM+
S-06, Mag-Hytec Covers
IAFF Local 1159
Shagginwagon is offline   Reply With Quote
Old 04-12-2009, 11:14 PM   #3 (permalink)
your gonna rub on hard turns. I just did some 35 12.5 tires with a leveling kit and they rub on the hard inside turns. I got an aggressive mud terrain tire and it definetly will rub even with a positive offset. I tried the following offsets and had rubbing 10, 6 -6, -12, no luck on any of them.
DieselDog208 is offline   Reply With Quote
Old 04-12-2009, 11:16 PM   #4 (permalink)
SHOOTIN FOR 550HP!!!
smokey burnouts's Avatar
If you get aftermarket control arms i think most of your rubbin issues will be resolved...
01 2500 4X4 QC LEVELED 35's on 17x10 KMCs: BHAF, JUICE(HOT), 150hp FIRESTORMS, 5" FBD STRAIGHT PIPED,J-HOOK, DTT VB, TCS 89% CONVERTER, BILLET SHAFTS, FDB BUILT TRANNY, HOLLEY PUMP, KIMBER 1911 SECURITY SYSTEM THANKS TO FARMBOYS DIESEL, WICKED DIESEL
WANT: 2500 5.9L 4x4 MEGA cab, handshaker, 6"lift on 37's, FBD 5", Smarty, gauges
www.myspace.com/74212921
smokey burnouts is offline   Reply With Quote
Old 04-12-2009, 11:19 PM   #5 (permalink)
That's what most have been saying, get new control arms and then you will be set.
Old 04-12-2009, 11:21 PM   #6 (permalink)
Aftermarket ones are round and smaller in diameter than the factory "U" shaped bulky ones
Old 04-13-2009, 12:44 AM   #7 (permalink)
Fisherguy's Avatar
What kinda wheels do you have, where do the tires rub?
I just put 35's on my H2's, they clear the fender by about 1/4" and only rub the inner fender, don't rub the control arms.
I'm going to take it for an alignment and ask them to crank the offset bushing of the lower control arm, hopefully that gives me enough clearance at the fender to put my mudflaps back on.
06 QC 3500, Raider cap; custom rack; DiPric gauges; 40" Nelson; S&B intake; BDTD CL; Quad X2: Pac Brake PRXB/air bags with Airlift Wireless; AD 100/Liberty canister; 4 KC's, Randy Ellis light bar; SB OFE, leveled, Bilsteins, 35" Vortracs/H2's; ATS Flares
Fisherguy is offline   Reply With Quote
Old 04-13-2009, 10:25 AM   #8 (permalink)
They hit the actual fender and of course the offset of -12 didn't help. I need to look at a 10 to 15 offset.
