Old 04-12-2009, 04:23 PM   #1 (permalink)
jsledder's Avatar
Tire wear concern
Rotating the tires on my Megacab today and took down some readings. It appears to me that the rear is suffering from over inflation and the front could have a slight aligment issue.
Front Left - 54psi, TD middle - .397, outside - .346, inside - .370.
Front Right - 54psi, TD middle - .383, outside - .384, inside - .345.
Left rear - 54psi, TD middle - .195, outside - .345, inside - .356.
Right rear - 54psi, TD middle - .203, outside - .347, inside - .354.
Door says to run 60psi in the front and 45 or 70 in the rear. (light load or max load).
Most of my miles are highway miles empty or with a 3000lb open trailer with about 600lbs tongue weight. Occasionally I have my 4 place enclosed and 4 sleds, probably 4-6 weekends/winter. Truck has just under 19k on it and the tires are the stock BF Goodrich all terrains. Very little gravel, no burnouts.
Tire experts..... should I drop the rear tire pressure to 45 and raise the front to 60?
jsledder is offline   Reply With Quote
Old 04-16-2009, 11:46 PM   #2 (permalink)
THE BDR
ryans01's Avatar
well....IMO---this is what i've found to be the best all around for me...i don't run anymore then 35-45PSI in the rears...now keep in mind the most i really pull is 5-8k...if i were to pull more then i would bump the rear pressure up...
in the front...when i was run'n load E tires, i always kept them at about 70-75PSI...kept them from cupp'n on me...now that i have load D rated tires i run the max which is 65psi in them...
hope this helps some...
ps...i rotate my tires every 10k too...
Ryan S.
"The BDR Edition" 2001 4 X 4, 3500, 2nd NV4500, II SO VP, SBC DD 3600 12CB w/ input shaft AND Valair HD HYDRO'S, TSTPM3, Edge EZ, AFE, FASS HPFP, 5" turnout stacks, gauges 319.9/776.8 4/25/09 DUNBAR'S DYNO
ryans01 is offline   Reply With Quote
Old 04-17-2009, 01:35 AM   #3 (permalink)
cverellen's Avatar
I'm runnin 45 on the rear 55 on the front.
03 2500 4x4, Quad Cab, Long Bed, Auto, Afe Stage 1, Edge w/juice
cverellen is offline   Reply With Quote
Old 04-17-2009, 08:49 AM   #4 (permalink)
THE BDR
ryans01's Avatar
for some reason i was thinking again.........thought you had a dually for second....
my buddy's 3/4 tn, he runs 55-60 front and 45-50 in the rear, this is on 315/70r16s....
Ryan S.
Old 04-17-2009, 09:34 AM   #5 (permalink)
ynots57's Avatar
i run 70 psi on my Michelins regardless of load, 42,000 miles, only rotated twice. the front is heavier, a turning tire and provides the most breaking force, the rear is the traction tire and with my driving habits the wear so far has been equal. when running max psi i also get better mpg because of less rolling resistance. I use to run 55 front (4400 lb) 50 rear (3300 lb) when empty.
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is offline   Reply With Quote
