Old 03-27-2009, 12:18 AM   #13 (permalink)
ontheedge's Avatar
Black Beauty - If you wouldn't mind man do you care to email me some pics of the lift and the long arms? Can hook you up with my email address or you can try to pm them to me. Thanks man
06' Mega Cab 4x4 Laramie, white w grey leather, tinted windows, bedcover, stepbars, 22x11 XD Diesel wheels w/ 37" Toyo MT's, 8" Rize Lift Kit
"I Use Ricers For Wheel Chocks"
ontheedge is offline   Reply With Quote
Old 03-27-2009, 12:24 PM   #14 (permalink)
the swamper irok comes in a 41x14.50x22 an the new swamper M16 comes in a 40x14.50x22
R.I.P 03 HO 3500 QC 4x4
Devilman is offline   Reply With Quote
Old 03-27-2009, 01:25 PM   #15 (permalink)
get vert's Avatar
Im running a 12" lift on 40"s. Go with the Toyo hands down. Much better mileage from them.
99 Dodge quad cab lb, 24v, ALL CUSTOM
get vert is offline   Reply With Quote
Old 03-27-2009, 09:10 PM   #16 (permalink)
black beauty's Avatar
those toyo's are pricey but i would like to have them, i dont do hardly any offroadin so i think they would fit my style a little better. how are the swampers on ware?
ontheedge- yeah, the coil spacers are on order so as soon as it gets on there and done ill send ya some pics of it. OR, i could take some with my phone and send them via text. i could do that asap for ya
1998 12valve Larmine.4gsk.s300 w/race cover.#100 plate.sb intake.FTE 435.17*timing.S&B CAI.CFM.6" stacks.studs.fire ringed head.hts extreme HD trans.tdtc. suncoast flexplate
black beauty is offline   Reply With Quote
Old 03-30-2009, 02:09 PM   #17 (permalink)
Just a little info. I was running 40x15.5 toyo mts I had an 8" rize 2.5 spacers on top adj.control arms 2" longer, adj track bar,5" block 4" skyjacker leafs, 2" thuren shackle, and 4.5 bs wheel. I had no rubbing at all, only problem was small vibe on front drive shaft. Now I'm running 8 rize and 38x15.5 kumho mts, there is pics on these site 10.5 on 40 If you want an idea. Also on a side note I'm selling the 4" skyjacker leafs I payed 600+shipping they are 3 months old I want 450+shipping just fyi
palady6.7 is offline   Reply With Quote
Old 03-30-2009, 10:02 PM   #18 (permalink)
You wouldnt happen to have those 40's tuckek back in the corner of your garage would ya??? and which do you like better? the old 10.5 inch lift on 40's? or your 8 inch on 38's
Old 03-31-2009, 06:52 AM   #19 (permalink)
AUTOBOX TRANSFORM!!!
SkinInc69's Avatar
I was hopeing to see some 12" high rigs with 40's in here.
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance BLACK MAXX, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
Old 03-31-2009, 11:15 PM   #20 (permalink)
You'll see one on this thread perty soon!
Old 03-31-2009, 11:25 PM   #21 (permalink)
Camotanker's Avatar
if you guys go with these lifts... make sure you get some sort of LONG ARM kit!!!
Monster Rig - (Website Click Here)
2003 CTD - REBORN
Camotanker is offline   Reply With Quote
Old 04-01-2009, 06:47 AM   #22 (permalink)
SuperliftMegaCab's Avatar
you will be fine. I have a 10in on 38.5 and I still have room to probably run 40s. with a 12 in you will be fine.
06' White Mega Cab CTD 10"Full Throttle Long Arm Lift, 38.50x14.50x18 Pro Comps,18x12 Weld Dune 8, Dual Superlift S/S, Edge J/w A, Built at J R Garage
SuperliftMegaCab is offline   Reply With Quote
Old 04-01-2009, 01:05 PM   #23 (permalink)
NCcummins's Avatar
12 inch would be awesome! and 40s would make it look even better....dude i hope you have a ladder to get into the truck
2003 Dodge Ram 3500 Dually: 08 Front End Swap, ARP Head Studs, DDP 100hp, 6spd, SB Clutch, FASS 150, aFe, MBRP, Predator, Rockstars, Valve Springs, PAC, TV, Subs, AMSOIL, 310,000 miles and counting.......
NCcummins is offline   Reply With Quote
Old 04-02-2009, 09:26 AM   #24 (permalink)
sorry I sold them cheap.The look the 10.5 and 40s, the ride and handling 8 and 38s
