Old 03-09-2009, 07:07 PM   #1 (permalink)
38x15.50's on 6" lift???
i see so many trucks on here with 6" of lift and 37's. just wondering if anyone is running anything bigger with only a 6" lift...I just ordered a set of 38x15.50x20 nitto mud grapplers for my 06 quad cab, and i have a 6" tuff country lift. i know i can clear them, but was intreasted in seeing some pics of other rigs with this combo.
RUNUOVER06 is offline   Reply With Quote
Old 03-09-2009, 08:09 PM   #2 (permalink)
Northern CA Chapter President
Neel's Avatar
just got to have the right offset on the wheels and you''l be fine.
2006 cummins 3500 laramie murdered out
13.5'' lift, 20x12's on 41'' iroks
TURBO ENGINEERING CORP. 617hp, stock cp3,stock lift pump, and on 41's
custom paint and amp step getting done
Neel is offline   Reply With Quote
Old 03-10-2009, 12:25 AM   #3 (permalink)
ClayCountyCummins's Avatar
6" tuff county lift will not clear them with out cutting inside fenders out of the front fender wells, however get a little coil spacer and it will clear the tires and wheels no prob...heres my 05' titan next to my 06' 2500 with 6" super lift with coil spacers and 38"15.50"20r claws with 20x10 black rockstars...lets just say the fender flares and inside fender took a beating from those tires because i didnt cut em out..
-2008 Dodge 2500 Cummins 6.7L Quad Cab SLT (Super Black) with lots of go fast parts...big tires and lift and built Suncoast transmission
ClayCountyCummins is offline   Reply With Quote
Old 03-10-2009, 12:29 AM   #4 (permalink)
Black Smoke Addict
RedRum's Avatar
when you say coil spacer, do you mean just a leveling kit? Did you have to get longer shocks? What about the trackbar? I've been wanting to do this, but advised by Superlift that it would cause bad geometry and driveline angles.
2007 3500 QCLB, 5.9, ISSPRO, AFE Stage 2, AF1 intake horn, Smarty, SB 3600#, Straight Piped with 6" Mitres, 6" lift, Bilstein 5100s/dual steering stabs., trac bars 37" BFG M/Ts, CUMMINS FORUM STICKER!May 2009 ROTM-Thanks to James @ RSD for stepping up!
2006 3500 QC Bighorn, 6 speed, No silencer ring, B&W turnover, other than that, stock
"I Caught that diesel thing, now it stings when I pee"
RedRum is online now   Reply With Quote
Old 03-10-2009, 12:32 AM   #5 (permalink)
hambone88's Avatar
hey clay county... How did it ride,drive,and effect the mpg... Not meaning to highjack the thread but I started a forum with the same questions...
red072500 quad cab,18in black xd monsters,37x13.50r18 dc md countries,6in superlift w/5100s,superlift dual stab bar w/ 5100s, ds predator,mp-8,5in fbd tbe, homebrew intake,fab four rear bumper,custom headache rack,bull bar,halo dual projector headlights..
hambone88 is offline   Reply With Quote
Old 03-10-2009, 12:35 AM   #6 (permalink)
hambone88's Avatar
How about a 1in spacer..I know I put a 2in spacer on there when it was stock and it made it right pretty rough!!...
Old 03-10-2009, 01:59 AM   #7 (permalink)
yea, a "leveling kit" is a coil spacer. i ran a 2.5" coil spacer
the shocks i ran were bilstien 5150s from the 6" superlift kit. and i had the dual shock mount essentially giving me 3 shocks.
i did not do anything different to the suspension, just 6" super lift kit with the coil spacer
as for superlift saying the geometry and drive angles being off, they are correct the geometry and drive angles would be not what the were intended for but the extra added lift will not hurt it, it will perform just fine
Old 03-10-2009, 02:03 AM   #8 (permalink)
it rode like a truck, it was not a horrible ride, but it wasnt like riding on a kelderman air ride kit or my buddies 8" spirson offroad kit...
and the mpg didnt change much, but the truck had around 650hp and just at around 1000lb ft tq
a 1" coil spacer wouldnt do much or effect the ride at all, but with just a 1" coil spacer you will not enough lift out of the front end to run the wheels and tires i had, maybe with a different offset of wheels a 1" coil spacer would be fine with minimal trimming of the fenders..
Old 03-10-2009, 02:05 AM   #9 (permalink)
I don't think you will fit them without ripping off a fender. The height isn't the prob., the width is. You see what I have on mine and it almost will rub. They are 14'' wide but not as tall(about 35.50). I don't remember my backspacing.
38'' tires will look incredible......as long as your driving in a straight line!! good luck.
2007 MEGA 4x4,no silencer ring,AFE stage 2 intake,5" Farm Boy Exhaust,Tuff Country 6'' lift.355/65/18(37) Kumho A/T, MOTO METAL 950,Flashpaq Performance setting,N-FAB 3 step bars w/Line X.Amsoil Bypass, Eclipse in dash Navigation/DVD, Sirius.
crashfirepm53 is offline   Reply With Quote
Old 03-10-2009, 08:27 AM   #10 (permalink)
well if they rub real bad, where can i get a spacer kit?and will it look bad with the front lifted 2 1/2 inches more than the back?
Old 03-10-2009, 11:16 AM   #11 (permalink)
Black Smoke Addict
RedRum's Avatar
There are several places that offer spacers. There are a couple of companies that make them that are advertised in the back of Diesel Power magazne. Also found these ones on ebay.
eBay Motors: BILLET ALUMINUM WHEEL SPACER 8 Lug Superduty 1/2" (item 110358748243 end time Mar-09-09 12:54:21 PDT)
Old 03-10-2009, 12:10 PM   #12 (permalink)
yeah but do i need wheel spacers or coil spacers? and how big of a project is it to install coil spacers?
