Old 03-08-2009, 12:40 AM   #1 (permalink)
285s 3rd gen dually
tired of looking ill just ask. If i put 285s on how much tire will be out past fender. 3rd gen dually. PA inspection laws suck
03 3500 4x4 6speed dually tube mod, ring+muffler mia, smarty, 4" x-factor lift, 35x12.5 M/T MTZ, 17x9 pro-comp rock crawler
busaboost is offline   Reply With Quote
Old 03-09-2009, 10:13 PM   #2 (permalink)
bump
nobody runs 285 i guess
Old 03-09-2009, 10:17 PM   #3 (permalink)
lawn & landscape pro
piersonslawnservice's Avatar
my guess is approx. 1.5-2 inches...cuz your gonna need a spacer to clear the tire...
my guess is based on my mega cab
06 Mega DRW, SPS 62, SmartyTNT/MP-8, Goerend, DTT , AirDog, Wicked, BD E Brake, Diamond Eye duals, 5in intake, Byrd, Ranchos, Eagle alloys in Nitto A/T, Amsoil, Opti lube XPD
02 LB7 Duramax -GT Turbo, Fass, EFI tuned w/dsp2 / MP-8 / Predator(scan tool), Suncoast V, Magnaflow duals, Pro Comp w/ XAT, Ranchos/ 3in lift, Amsoil, 2 stroke/ Opti lube
piersonslawnservice is offline   Reply With Quote
Old 03-10-2009, 01:04 PM   #4 (permalink)
Neight's Avatar
Right around 1.5". Most guys run a 2" space to clear these I have read a few posts where some guys have ran a 1/4" or 3/8" but they have all said that the tires are way to close.
06 Megacab dually 5.9 Auto, Diprocol Gauges, 5" turbo back FBD exhaust w/ muff,AFE Stage 2 w/PG7 filter, Smoked Recon tail, cab, brake lights and the Smarty ACDC
Neight is online now   Reply With Quote
Old 03-10-2009, 02:30 PM   #5 (permalink)
Cowboy 2.0's Avatar
If u put two inch spacers on 285's, your truck will look retarded with that much space, I've seen it, looks bad. I know of 3 trucks in town right now running 285's on 3rd gens and they run a half inch of space and they never rub what so ever.
2008 3500 Laramie Mega Dually 4x4 Smoked Lights, 3 inch Leveling Kit, 315/70/17 Nitto Dune Grapplers, Smarty, Dr. Performance rail box
Cowboy 2.0 is offline   Reply With Quote
Old 03-10-2009, 06:42 PM   #6 (permalink)
I am running 285's on mine and only a 1/4" spacer in the rear with no problems. When towing a run max pressure and have no signs of them touching. I will take some pictures and post them later tonight.
05 Dually 4X4 Motor by Scheid Diesel, Tranny by Goerend, Balanced by Fluid Damper, II CP3 & tow twins, MP8, Smarty, Mag-Hytec diffs&trans, GDP-Raptor fuel system, Scheid inj, Traction Bars by Crooks MotorsportsUNA GOOSE & DURAFLAP Mid-west Dealer
snoxracer is offline   Reply With Quote
Old 03-10-2009, 09:22 PM   #7 (permalink)
HOTRODBRB
HOTRODBRB's Avatar
I was dealing with the same thing and I just order 265/70/17's for my mega cab dually!!! Live in Pa and I didnt want to deal with JOHNNY LAW!!!! Ive seen chevy duallys and it dont look so hot with spacers,stuck out 1.5 inches out of wheelwell and it didnt look so hot!!! MY OPP! Like I said I ordered mickythompson atz's. Should have them on this week! Hope info helped!
HOTROD
2007.5 - DODGE MEGA CAB DUALLY: 6.7 WITH 6-SPEED AUTO, AFE MEGA CANNON AIR FILTER, ISSPRO WHITE FACED 3-POD GAUGE KIT, TS PERFORMANCE MP8 gone!!! H&S EGR DELETE AND COOLER DELETE, H&S XRT PROGRAMER WITH 5 INCH EXHAST INTO 7INCH MITERCUT STACKS !!! GOT COAL NOW!!!
HOTRODBRB is offline   Reply With Quote
Old 03-11-2009, 03:36 AM   #8 (permalink)
ram rod's Avatar
ok well i went to ntb today to put 285 70 17 and they dont fit , i had 1/2 inch spacers i bought like a year ago and with them on you cant tighten up the lugs ,with out the the tires touch when the trucks on the ground , this may be do to the fact i have egale alloys on the truck witch really pisses me off , then i called the local 4 wheel parts and they wanted to sell me the 2inch spacers i didnt want that wide because i think it will look stupid and they told me it would be $829.00 for 2 fu***** spacers , well being upset with the whole deal i got the mic AT2s 265 70 17s,and im very unhappy because i spent $1300 and i hate the way they look im thinking of going back tomorrow and trying to figure something else out i wonder if a 1/4 will work but i dont know if they will let me take them back
RAM ROD 2006 1ton 4x4 dually, 2 inch leveled, eagle alloys ,superchips tuner, 4inch mbrp no muffler, cfm intake maifold, afe cold air intake,nfab 6 steps,line-x , make some smoke
ram rod is offline   Reply With Quote
Old 03-11-2009, 03:50 AM   #9 (permalink)
cummins freak's Avatar
jsut get longer studs or different lugs
1997, 2500 CTD. 4x4 LWB, ext cab, MODS-#100 plate, JL Machine 5x0.016 Injectors, 3kgsk, timing at 16*, Dave G. trans, , HTT killer B II 64/14, Custom DV's from weston!!! Mods soon to be- traction bars,head studs, marine gasket.
cummins freak is offline   Reply With Quote
Old 03-11-2009, 08:57 AM   #10 (permalink)
Cowboy 2.0's Avatar
Thats odd. One of the boys from town that runs them with a half inch of space is running them on eagles.
Old 03-11-2009, 10:19 AM   #11 (permalink)
HOTRODBRB
HOTRODBRB's Avatar
RAMROD did you get the mickey ATZ's or the ATZ RADIAL PLUSES ??? The baja atz radial pluses look like car tires!!!! And there more money!!! The baja atz are like an offroad radial but not a mud tire. I was just woundering????
HOTROD
Old 03-11-2009, 12:07 PM   #12 (permalink)
Neight's Avatar
Post up some pics. I want to run 285's on my dually but I agree a 2" spacer doesn't look so good with 285's. What brand of tire you running and what is the LR?
