Old 03-07-2009, 10:19 PM   #1 (permalink)
9812v5spd's Avatar
38s on 16" wheels
pros and cons, i like the older skool look w/ 16" wheels, on meats like some 38s.
98 qaud cab long bed, 12V,3k GSK, 15* timing, nv4500 w/ SB 1 3/8" input shaft, SB con ofe, 5th gear nut, #100 plate, BHAF, 5" straight pipe, pyro/boost gauges , 8" RCD long arm, 385/70 MUD GRAPPLERS(37x15.5x16s)
9812v5spd is offline   Reply With Quote
Old 03-08-2009, 03:55 AM   #2 (permalink)
scottd53's Avatar
i agree with you on that.. not a big fan of big wheels with low profile tires on trucks.. im hoping to get 38's some time.. i cant decide on what tire tho..
01 2500 auto w/Edge Comp, Edge Jammer 125hp nozzles, Super B Special, DTT TC and VB, FASS 150/150, 5in straight to black 6in turn-outs, 6in AMSOIL filter , 7in lift w/ 38x15.5 Baja Claws, Autometer Gauges... EGT,Boost,Fuel Pressure,Tranny Temp
scottd53 is offline   Reply With Quote
Old 03-08-2009, 03:04 PM   #3 (permalink)
Northern CA Chapter President
Neel's Avatar
options are limited now days on that combo. but, i think it looks good.
2006 cummins 3500 laramie murdered out
13.5'' lift, 20x12's on 41'' iroks
TURBO ENGINEERING CORP. 617hp, stock cp3,stock lift pump, and on 41's
custom paint and amp step getting done
Neel is offline   Reply With Quote
Old 03-08-2009, 03:07 PM   #4 (permalink)
looks great. im against 20's it looks like if you get in wet grass and sink down a half inch you could tare out your valve but it would probably handle better on 20's... still looks way better with 16s
05 Dodge Cummins 3500 SLT Crew Cab Auto 4x4 35/12.50/R17 Pro Comp Xterme All Terrain 2" level turbo back straight pipe silencer ring MIA Smarty TNT
tripple nickel is offline   Reply With Quote
