Old 03-05-2009, 10:14 AM   #1 (permalink)
Wheels will not fit?
I have a 99 Dodge Ram 2500 heavy duty 4x4 diesel with the factory 16 inch chrome rims. I purchased a set of the factory 16 inch aluminum wheels from a 2001 model Ram thinking they would fit. The local tire dealer says they will not go over the rear brake hubs. Do I have to find wheels from a heavy duty truck or ?
jonathan843 is offline   Reply With Quote
Old 03-07-2009, 05:05 PM   #2 (permalink)
cummins5390's Avatar
u can grind down the drums i was told 1ce
2001 Dodge ram 2500 6 speed..ARP studs...Hot juice with attitude...ats arcflow...airdog 150...edge jammer 125s..afe stage 2...5inch exhaust w/ 6inch tip...ATS auroa 4000...southbend 3600 dualdisc clutch...-Seth
cummins5390 is offline   Reply With Quote
Old 03-07-2009, 06:32 PM   #3 (permalink)
You need to find a wheel that has a higher offset, they way they won't get in the way of the drums
DieselDog208 is offline   Reply With Quote
Old 03-07-2009, 10:37 PM   #4 (permalink)
DRT086.7's Avatar
Have you tried them yourself because there are plenty of trucks running those rims...
08 6.7 6-spd man Quadcab 4x4 EGR all gone, Shibby Grid Heater+Stage 1 Intake horn, 5" SS TBE, AFE intake tube, Airaid, Edge, Diablo EPP, Pure Performance 4", SBC DD 3600, 35/12.50x18s on Jesse James Lawless8's, Recon cab lights 487hp/972tq
DRT086.7 is offline   Reply With Quote
Old 03-08-2009, 09:47 PM   #5 (permalink)
Wheels that will not fit
Thanks for the reply(s). I will try putting them on myself, if that does not work I will look at other options. I have seen these wheels on numerous other dodge trucks, and I would like to stay with the 'factory' look. This is my first cummins and I am lovin it...........still got a lot to learn, again thanks.
Old 03-08-2009, 09:50 PM   #6 (permalink)
0124vctd's Avatar
I had to do this on a buddys truck. We had to grind down the drums a little and took a little off the rims also. On the front you have to grind a little off of the corner of the tie rod bracket to make the fronts fit. I sux but can be done.
2001 2500 Some gauges and BLACK Stacks It's just a little six cylinder.
0124vctd is offline   Reply With Quote
