Old 03-04-2009, 11:09 PM   #1 (permalink)
35s with 3in lift
im thinkin a bout gettin a 3in lift or the kore hp series kit and i was wondering if either or both ways i could run 20+10 rims with 35 in tires. thanks
06 reg cab trx4 2500 6spd 4x4, muffler and kitty fell off. isspro gauges(egt, boost, fuel psi) smarty. s&b cai
5.9ram is offline   Reply With Quote
Old 03-04-2009, 11:12 PM   #2 (permalink)
mjd91's Avatar
It will most likely depend on the backspacing and offset of the wheel.
2000 short, 4x4, 6 speed, 12.25" DD Valair, S.O.VP44, AEM Brute Force HD, FBD 5" with 6" tip, ADRENALINE!!!, AirDog II 165, AutoMeter Cobalts, 35" Mud Grapplers on 18" Black XD Diesels
mjd91 is offline   Reply With Quote
Old 03-04-2009, 11:29 PM   #3 (permalink)
AUTOBOX TRANSFORM!!!
SkinInc69's Avatar
Does the kit come with longer control arms?
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance BLACK MAXX, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
Old 03-04-2009, 11:46 PM   #4 (permalink)
the kore is the hp leveling series so i dont think so and if i got the 3in lift it would be a bds and idk bout that either.
Old 03-04-2009, 11:48 PM   #5 (permalink)
SkinInc69's Avatar
The BDS doesnt come with new control arms. I put longer ones with 3" BDS so I could clear the sweap of my 20x12 with -51mm offset. Well kinda clear them.
Old 03-04-2009, 11:53 PM   #6 (permalink)
ic im new to lifts and i dont know much about all the offspacing and what not. i would like to get 35s on some wider than stock rims but dont want to lift much higher than 3in cause i tow with a gn tralier. idk what to do. lol
Old 03-05-2009, 12:00 AM   #7 (permalink)
SkinInc69's Avatar
Riley5.9 had the BDS 3" lift with 35x13.5 tires on 20x10's with 4.5" BS and they rubbed abit at full lock. You should be fine as long as you arent offroading hardcore.
