Old 03-04-2009, 12:43 AM   #1 (permalink)
tangowhsky's Avatar
speedometer recalibration
Does anybody know if I can recalibrate my speedometer with my buddies smarty and it not delete when the smarty is removed?
2005 Black QC 3500 SRW Laramie, 4x4, Sunroof, Leather + 8" RIZE with 37x13.50r20 Toyo M/T's on Eagle Alloy 0646 wheels + 6" stacks + Volant cold air intake + Smarty S06 + Shocker 548
tangowhsky is offline   Reply With Quote
Old 03-04-2009, 12:51 AM   #2 (permalink)
Shainer's Avatar
I always wondered the same thing...
I seriously doubt it will work that way. Removal of the Smarty programming would remove the tire calibration.
'98 24v. 5 speed. 4" exhaust. Some extra air and fuel here and there... The anti-Union.
Shainer is online now   Reply With Quote
Old 04-10-2009, 08:37 PM   #3 (permalink)
Smoke um up's Avatar
Bump, anybody got an answer to this, Im wondering the same thing
2006 Dodge 2500 with Cummins (of course!) , Quad LB, Banks Monster exhaust, MIA is the silencer ring and the kitty cat, Banks ram air, Edge juice w/attitude HOT, 2.5" levelers 18x9 Eagle Alloys 197 w/ 325/65/18 nitto terra graps
Smoke um up is offline   Reply With Quote
Old 04-10-2009, 10:27 PM   #4 (permalink)
hntnwgn's Avatar
It should work, I know you can use it to read and clear codes on another truck. When you change the tire size you don't actually down load a program.
2006, ,CAI, isspro gauges, cat delete, 41" donaldson, smarty,airdog 165, TRE billet trans, 4.5 Fabtech, 35" nitto terra grapplers, 18x9 moto metal 955's
hntnwgn is offline   Reply With Quote
Old 04-10-2009, 10:30 PM   #5 (permalink)
scottd53's Avatar
the dealership is an option..if they will do it for you
01 2500 auto w/Edge Comp, Edge Jammer 125hp nozzles, Super B Special, DTT TC and VB, FASS 150/150, 5in straight to black 6in turn-outs, 6in AMSOIL filter , 7in lift w/ 38x15.5 Baja Claws, Autometer Gauges... EGT,Boost,Fuel Pressure,Tranny Temp
scottd53 is offline   Reply With Quote
Old 04-10-2009, 10:34 PM   #6 (permalink)
I tried doing it with a buddys smarty with it still programmed to his truck and it would not let me do it saying it was VIN locked, so we took it off his truck and put it on mine and it will not let you change tire size without a catcher tune installed, so what i figure is if you programmed it to your truck, and set the new tire size and then set it back to stock and maybe it would still be set. worst case senario would be that it clears that too but it will enable high idle so its not a total loss
Old 04-10-2009, 11:11 PM   #7 (permalink)
hntnwgn's Avatar
I stand corrected!!! According to the website the abs section IS VIN locked! You can only read codes without it being vin locked. Sorry for the misinformation.
