Old 03-01-2009, 09:17 PM   #1 (permalink)
HOTRODBRB
HOTRODBRB's Avatar
HELP! Need new tires for 07.5 dually!!!
I am looking for a beefy tire for my megacab dually! i dont want to put the stock gumbands back on it!! I need a tire that will not rub each other in the back when hauling a load or trailer! I like the nittos, interco,or mickeys! If you guys can help me out with some pics or size or both that would be great!!! SHOW MEE WHAT YA GOT !!!! The factory size tire is 235/75/R17 . Im looking to go to a 255 maybe!! HOPE to see or here something soon! Thanks Ben .....
HOTROD
2007.5 - DODGE MEGA CAB DUALLY: 6.7 WITH 6-SPEED AUTO, AFE MEGA CANNON AIR FILTER, ISSPRO WHITE FACED 3-POD GAUGE KIT, TS PERFORMANCE MP8 gone!!! H&S EGR DELETE AND COOLER DELETE, H&S XRT PROGRAMER WITH 5 INCH EXHAST INTO 7INCH MITERCUT STACKS !!! GOT COAL NOW!!!
HOTRODBRB is offline   Reply With Quote
Old 03-01-2009, 09:35 PM   #2 (permalink)
Over Fueled and Budget
Magic smoke's Avatar
I really like the dura grapplers. 235/80/17's are what I run. No pics, but pick up any truck magazine and I'm shure theres an ad if they aren't on the back cover. I'm not shure they live up to all the hype but they wear the best of any tire I've run so far.
Early 04 3500 drw quad cab-6speed SBC fast coolers - 4x4 -S&B -fass 150-expandit 5"- FTE resonator -SMARTY-autometer C2 full pillar gauges- di-pricol rpg-Dragonslayer cp3-64/71/14-PDI manifold -Wicked 125's - $2 rail cap.
Magic smoke is offline   Reply With Quote
Old 03-02-2009, 02:04 AM   #3 (permalink)
ram rod's Avatar
the biggiest you can go on no spacers are 265 70 17 and nearly ever tire company makes that size in a e load range got the bfg a/t on mine in that size looks alot better
RAM ROD 2006 1ton 4x4 dually, 2 inch leveled, eagle alloys ,superchips tuner, 4inch mbrp no muffler, cfm intake maifold, afe cold air intake,nfab 6 steps,line-x , make some smoke
ram rod is offline   Reply With Quote
Old 03-02-2009, 03:11 PM   #4 (permalink)
txag09's Avatar
Ram Rod Do you have any pics. of your tires on your truck? I need some new tires as well and was thinking about that size. Also how much taller are your new tires over stock?
2007.5 Patriot Blue 3500 6.7L QC, 4X4, trippin gears w/ the 6 speed, 3.73, Smarty, Arson Jr, Valair DD, Airdog 150, 5" TBE, GHD,3.5" intercooler tube, EGR & DPF delete. KM2 255/80R17, 470hp-853 torque with smarty, 493hp-883 torque with XRT
txag09 is offline   Reply With Quote
Old 03-02-2009, 03:31 PM   #5 (permalink)
Cowboy 2.0's Avatar
I'm running 315/70/17's on my mega cab dually. 2.5" spacers in the back and everythings good to go.
2008 3500 Laramie Mega Dually 4x4 Smoked Lights, 3 inch Leveling Kit, 315/70/17 Nitto Dune Grapplers, Smarty, Dr. Performance rail box
Cowboy 2.0 is offline   Reply With Quote
Old 03-02-2009, 11:14 PM   #6 (permalink)
HOTRODBRB
HOTRODBRB's Avatar
RAMROD im looking not to use spacers do to the fact i dont want them to stick out !!! My other dalema is do your tires rub and if not how close are they together!!! I do tow some times and dont want probs!!! I do see that ever body has that size you said and thats awsome if there are none of these problems with them!!! Is there any way you can get me a pic of your truck in the center of your tires and from the side that would be great!!! Thanks for the info guys !!! KEEP UM COMIN!!!!
HOTROD
Old 03-03-2009, 12:28 AM   #7 (permalink)
Cowboy 2.0's Avatar
I had 265/70/17's on my last dually and i put a half inch of space between them just to be on the safe side. I also have a good friend that runs 285's on his with a half inch of space and they don't rub and he pulls some pretty heavy loads.
Old 03-03-2009, 01:31 AM   #8 (permalink)
ram rod's Avatar
sorry i dont have any pics as up yet and im going with a 285 next time just want a bigger tire but not 315s sence i drive alot ,06 with 75k on her already , but 265s with no spacers there is prob an inch or a little more so towing wont be any prob, tire is only a little taller but about an inch wider look 10 time better , i hated the 235 80 17s looks like pizza cutters i took them off and put bfgs on asap ,if i were you i would go with the mic at2s great tire
Old 03-03-2009, 02:27 PM   #9 (permalink)
homewrecker's Avatar
Heres 265's with 1/4" spacers.I tow heavy and have never had an issue.They are about a 1/2" shorter than the stock 235's.I'm going with 285's next just to fill up the fender well a little better.
05 QC Dually 4x4 Smarty TNT/R pod/MP-8,F1 injector's & springs,HTT,Floor-It stage 3,Fass,Southbend,ARP,ATS,Opie By-pass,Fluidampr,lots of gauges
homewrecker is offline   Reply With Quote
Old 03-03-2009, 06:00 PM   #10 (permalink)
ram rod's Avatar
how you like your cooper stt?
Old 03-03-2009, 07:21 PM   #11 (permalink)
They are Cooper st's.The stt is the m/t.I love them.Got right at 25k on them with a little under half tread remaining.They might go 45k if I stay on top of rotating them.They hum a little but you can't hear it in the cab over the exhaust.The only reason I know they hum is my friend has them on a F250 gasser.
Old 03-03-2009, 10:11 PM   #12 (permalink)
HOTRODBRB
HOTRODBRB's Avatar
Thanks guys for the info!!! Homewrecker those tires look awsome!!! I would like to get the micky thompson atz but alittle pricey!!!! WILL HAVE TO SEE WHAT MAMA SAYS!!! lol! kEEP THOSE PICS AN INFO COMIN!!!! Thanks alot guys for the help!!!
HOTROD
