running d rated tire need help!!!
ended up getting sent a set of 285/75-16d goodyear mtr noticed that they are 1500kg and my current tires are 1550kg. would i be ok running these or should i try to trade them at a goodyear store?
2002 Ram 2500 4by Auto SB (Brushtruck):Autometer gauges, Edge Comp, BD Stealth cover, silencer ring mia, no muffler or cat,285 goodyear mts, leer cap. |
#3 (permalink) |
sent him my choices and sizes and guess he couldnt find a 285 in an e. had all the ones listed
#5 (permalink) |
but what psi should i run them at? i run my currents at 60 and i think those are the mtr's max
#6 (permalink) |
Posting Suspended
Well, 50kg's is a diff of what, 100lbs? They basically are rated to hold the same amount of weight. Check the sidewall, see what the max pressure is per tire, and then put it near there in the front and a little lower in the back.
#8 (permalink) |
TECH SPECIALIST
![]() Join Date: Jul 2008
My buddy has run Ds for a year and a half. Walmart specials Still in good shape even with 500hp and a few burnouts.
2000 QCSB, built auto, P7100, 131 dvs, 4gsk, .084 lines and tubes, 7 x .014s, 22*s, maxspool 2.5 cam, 110# valve springs, 125ft lb head bolts, 66/74/.9 ohiocoalrollers.com
#9 (permalink) |
I ran D-rated BFG AT KOs for 58,000 miles including heavy towing and hauling. I ran the max PSI on the sidewall (65psi) and rotated every 7500. No problems.
2004 2500 SLT SWB 4x4,305/555, in-tank lift pump, 48RE, 3.73, westin cps step bars, magnaflow pro 4" TB, 305/65/17 BFG AT KOs,Timbrens, Leer Cap, Firestick CB antenna mounts, Wilson Silverload 5' antenna, Uniden PC78LTW CB |
#11 (permalink) |
there is only 50kg difference, dont worry. just keep within the load rating
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO |
