Old 02-26-2009, 01:28 AM   #1 (permalink)
wcopp's Avatar
Cooper STTs load range
I had these tires on my 1/2 ton but Im afraid to use them on my 2500 due to the load rating 35x12.50x17
2007.5 6.7 QCSB Silver 4x4 68rfe - 2.5in. HBS/2in. Rear blocks,35 BFGs,Lazersmiths SSSSS,Lazer links,Offset trackbar bushings,AFE,RSD 5in.TBE,6in.Tip,Shibby Deletes,XRT 175
wcopp is offline   Reply With Quote
Old 02-26-2009, 11:07 AM   #2 (permalink)
scottd53's Avatar
alot of my friends run them on their trucks and so do i...i like them... no complaints..i have about 15k on them and they have 75% of tread left maybe more
01 2500 auto w/Edge Comp, Edge Jammer 125hp nozzles, Super B Special, DTT TC and VB, FASS 150/150, 5in straight to black 6in turn-outs, 6in AMSOIL filter , 7in lift w/ 38x15.5 Baja Claws, Autometer Gauges... EGT,Boost,Fuel Pressure,Tranny Temp
scottd53 is offline   Reply With Quote
Old 02-26-2009, 11:10 AM   #3 (permalink)
bakedogg83's Avatar
Mine are load range E. So far a great overall tire, but I have to get them rotated every time I change the oil. The seems to be law with Coopers.
2004 Dodge 2500 4X4 - It has some goodies on it. Just need to find some more money.
bakedogg83 is offline   Reply With Quote
Old 02-28-2009, 03:21 PM   #4 (permalink)
Discount Tire Direct
Discount Tire Direct's Avatar
Understandable wcopp. Your truck calls for a minimum 120 Load Index. The STT you are looking at is only 119. Not a huge difference but if you tow, it may not be the best option because it's only D rated. You should look into the Hankook DynaPro MTRT03.
America's Largest Independenly owned Wheel and Tire Retailer
www.discounttire.com
Discount Tire Direct is offline   Reply With Quote
Old 03-01-2009, 11:58 AM   #5 (permalink)
I run 285/70/17's on my 06 quadcab. They are load range D and I have never had any problem towing. Also do a lot of driving on rough dirt roads and have never had a stone punch either. This is 2nd set on this truck and went through 3 sets on my 03 2500. Hope this helps you out.
skidoo hauler is offline   Reply With Quote
Old 03-01-2009, 08:29 PM   #6 (permalink)
wcopp's Avatar
Thanks guys all was very helpfull
