Old 02-22-2009, 10:25 PM   #1 (permalink)
Cummins_Chevy's Avatar
ProComp Radial A/t worth it?
I'm looking at buying a set of these, so, are they worth it? Are they a good tire? How long do they last? ect.
http://www.4wheelparts.com/Tires/Rad...0806&t_pl=3357
1991 W350 CTD NV4500/NP205. 5" lift, 35" BFG m/t's, HX40, soon to get a p-stroke IC
I'd rather have a straight six than a bent 8
Cummins_Chevy is offline   Reply With Quote
Old 02-22-2009, 10:35 PM   #2 (permalink)
Its a Diesel Punk!!'s Avatar
i will let ya know in a couple days,,, should be gettin mine tomorrow or tuesday,,,im goin from stockers 265/70/17 to 315/70/17,,,,,see what happens
07 5.9 auto 4x4 QC LB,,,Smarty Jr POD,,,,Icebox w/ S&B filter,HELL BENT 2" levelin kit,4" homemade str8 piped w/ 6"tip, Recon smoked cab lights,Rat Black H2s w/ 35" Pro Comp Xtreme A/T's....Phantom Gauges,Boost,Pyro,Trans Temp
Its a Diesel Punk!! is offline   Reply With Quote
Old 02-23-2009, 05:42 PM   #3 (permalink)
Well, nevermind, my deal fell through.
Old 03-16-2009, 07:19 PM   #4 (permalink)
2004.Ram.2500's Avatar
You know if ProComp Xtreme All Terrains 315/70/17s will fit on my stock rims? Are they gunna be too wide because my rims are only 7.5 wide?
2004.Ram.2500 is offline   Reply With Quote
Old 03-16-2009, 07:31 PM   #5 (permalink)
i don't see a 315-70-17 on their site
2007 Dodge 2500 Quad Cab Short bed 4x4 Laramie with the 5.9. 285/75/17 Toyo Mt
99mariah is offline   Reply With Quote
Old 03-16-2009, 08:47 PM   #6 (permalink)
I just found that out too. Just for refernece look at the BFG KO. It might be a little difference in size but see it it'll work.
Old 03-17-2009, 10:07 AM   #7 (permalink)
bfg
did you put them on your truck? Pics? any rubbing
Old 03-17-2009, 10:15 AM   #8 (permalink)
Dad
Administrator
Dad's Avatar
The ProComp's are a much softer compound than a lot of tires, BFG's for example. Good and bad in this. The bad, the set of P/C AT's we have are getting down to wear bars at 15K miles. The good, absolutely no death wobble, wheel shake, road noise or excessive rock throwing.
Dad is offline   Reply With Quote
Old 03-17-2009, 01:20 PM   #9 (permalink)
No, I havent even bought any yet. Stil loking around and saving up. Jus getting things in line ahead of time
