Old 02-21-2009, 05:24 PM   #1 (permalink)
the.silverbullet's Avatar
H3 Rims
I found a set of H2 rims for a real good price. My question is what modifications do i have to do to get them to fit on my 99 and how much will it cost. Thanks
the.silverbullet is offline   Reply With Quote
Old 02-21-2009, 05:28 PM   #2 (permalink)
booost yooo
mahdey's Avatar
seriously? Do you not know that H3 rims are 6 lug with a 5.5 pattern?H2 will fit with some milling but there is no cheap way or logical way to fit h3 rims on your 8 lug truck.
2000 2500 QCLB AT, 4x4. Auto to manual to auto swap, Goerend Transmission,150hp sticks, 5" Exhuast, AD 150, ADR/Pulse, twins in the works.
Thanks to Coaltrain Diesel Performance, Rollin Smoke Diesel
Ohio Coal Rollers
mahdey is offline   Reply With Quote
Old 02-21-2009, 05:39 PM   #3 (permalink)
I miss typed that i ment H2 rims. Is there anyway to change the title.
Old 02-21-2009, 06:39 PM   #4 (permalink)
booost yooo
mahdey's Avatar
oh hahaha i was hoping you mistyped. You have to mill out the center a little bit to fit the bearing lip. That is all you have to do. You can use a dremel for this.
Ohio Coal Rollers
Old 02-21-2009, 09:28 PM   #5 (permalink)
Ok thanks, thats what i wanted to know.
Old 02-21-2009, 10:19 PM   #6 (permalink)
Fisherguy's Avatar
Do a search, lotsa people have had real good luck using a router with a flush bit.
06 QC 3500, Raider cap; custom rack; DiPric gauges; 40" Nelson; S&B intake; BDTD CL; Quad X2: Pac Brake PRXB/air bags with Airlift Wireless; AD 100/Liberty canister; 4 KC's, Randy Ellis light bar; SB OFE, leveled, Bilsteins, 35" Vortracs/H2's; ATS Flares
Fisherguy is offline   Reply With Quote
Old 02-21-2009, 10:25 PM   #7 (permalink)
Smokin'
Hot Stuff's Avatar
Read through this............
Hummer H2 Wheel Upgrade
'03 Black 2500 QC/LB 4x4, 6 speed, BHAF, 2" lift, black H2's, 35" BFG MT's, B&W turnover, Juice w/ Attitude, 5" str8 pipe, BD lift pump, spin on filters, Firestone bags
Ohio Coal Roller
Hot Stuff is offline   Reply With Quote
Old 02-22-2009, 02:25 AM   #8 (permalink)
BlackedOut02's Avatar
i used a 1/2'' drill. i found if you spin the aluminum bits too fast, they clog up. i figured this out after my dremel and die grinder ate a couple .
'02 | 2WD | 2500 | NV4500
"Diesels dont run away. Diesels over speed, mechanics run away"
BlackedOut02 is offline   Reply With Quote
Old 02-22-2009, 03:09 PM   #9 (permalink)
Thanks for the info.
Old 02-22-2009, 03:22 PM   #10 (permalink)
nomoney nobrains's Avatar
So are our wheels hub or lug-centric?
95 long bed reg cab 4x4 4.10's 5sp, SBC DD 3600, 6" Awsome Aussie's, BHAF, Pro Comp Xtreme MT's
nomoney nobrains is offline   Reply With Quote
Old 02-22-2009, 03:25 PM   #11 (permalink)
Smokin'
Hot Stuff's Avatar
They are LUG centric. Don't let anybody tell you otherwise. I hate having this discussion. Sorry. No offense.
Ohio Coal Roller
Old 02-22-2009, 03:27 PM   #12 (permalink)
Smokin'
Hot Stuff's Avatar
ANYTHING that uses a tapered seat (acorn) style lug nut, is lug centric. If it uses a flat nut and or a washer, it's going to be hub centric.
Ohio Coal Roller
