Old 02-10-2009, 10:40 AM   #1 (permalink)
Will these work?
on a 2003 dodge 2500 4x4, 325/60r18E on eagle alloy series 197 18x9 with -11mm offset and 4.5 backspacing?
Also I am in a delima on the tires. I was looking at the the nitto dune grappler because there about the only ones in a 33 inch tire with 10ply. So if you know of any tires that arent mud tires post them up. Or does everyone think that i should go bigger than a 33 inch tire.
shroyer702 is offline   Reply With Quote
Old 02-10-2009, 02:31 PM   #2 (permalink)
Discount Tire Direct
Discount Tire Direct's Avatar
You may have to level the front to get them to clear. These are 1.75" taller than a stock 265/70R17 and about 2.37" wider.
This wheel and tire set up will sit out a little over 3" further than where the stock 17" wheel with a 265/70R17 sits. This is outside of what our guide recommends so I can't tell you more than that. You will want check to see if you have the space to clear.
Tire Size Calculator
What are you looking for in a tire? Do you tow? Are you looking for a highway tire or an offroad tire?
America's Largest Independenly owned Wheel and Tire Retailer
www.discounttire.com
Discount Tire Direct is offline   Reply With Quote
