Old 01-15-2009, 05:50 PM   #1 (permalink)
One step at a time
Harley27's Avatar
Guys with 315's
What tire pressure are you running in your 315/70 17 load D???
Got 50 in them now and feels rough.
2006 Ram 2500 QC SB 6 Speed 4X4
Smarty, High Ram intake, Silverline turbo back, AEM Workhorse, Auto Meter Fuel, Boost, EGT, South Bend DD, Fluidamper, Kore HP. Airdog 150.
Harley27 is offline   Reply With Quote
Old 01-15-2009, 05:59 PM   #2 (permalink)
I'm runnin 50psi as well. The truck is way smoother than my old '98 cummins!
2008, 4x4, QC, LB, Manual Tranny, AO Flash, 315 H2's, A-pillar triple guages, Air Raid intake, BlackTech, S67
Bando is offline   Reply With Quote
Old 01-16-2009, 07:40 AM   #3 (permalink)
One step at a time
Harley27's Avatar
Thanks. the roads are all snow and ice so its hard to tell how the truck rides.
Old 01-16-2009, 09:18 AM   #4 (permalink)
Run these in my old GMC
50 psi
John 3:16, John 14:6. Mega Cab Dually G56 2wd, Dr. P. 110/220, exhaust cutout, Traction Bars, leveled, Gooseneck, Iggee seat covers, Tekonsha Controller, Opti Lube Summer Blend, Mopar Tailgate Spoiler, Rokktech, '03 KX250/310, '01 KX500, '82 Yamaha 465
Joe Reitman is offline   Reply With Quote
Old 01-16-2009, 09:24 AM   #5 (permalink)
little semi
cummins 1ton's Avatar
Just going from my stock cookie cutters to some 35 inch mt's I noticed the truck rides way nicer. But I run 50 up front and 35-40 in rear(unloaded) but 50 all around loaded
07.5 1ton 6.7l cummins, G56, 4x4, on board air, nathans K3 train horn, 2" leveling kit, 35" toyo mt's, all the deletes, edge juice w/attitude race (used for gauges), XRT w/ hot dam 175 ATT, volantCAI, 5"TBE, FASS 150, turbo silencer MIA, south bend DD3600, spearco intercooler,
POWER MODS DONE BY BLACK TEK DIESEL PERFORMANCE
cummins 1ton is offline   Reply With Quote
Old 01-16-2009, 09:38 AM   #6 (permalink)
cutworm's Avatar
I have 315's, I run 40 in the rear and 45 in the front without a load. Smooth ride. I run 45 in the rear and 50 in the front loaded. But right now its gelled up because its -15 degrees and dumba$$ me didn't have any treatment in the tank last night. Sucks.
'06 2500 4X4 Laramie SLT, Bullydog-w/Monitor on Crazy Larry, Triple clutch TQ, upgraded valve body, new racing clutches, 2" level kit, MDRP 4" Duals, Quadzilla cold air intake box & Boost Fooler, Airdog 150, 33" BFG, Dyno'd @ 512 HP & 1110 TQ
cutworm is offline   Reply With Quote
Old 01-16-2009, 09:56 AM   #7 (permalink)
CORRECT AIRDOG INSTALL
05pscc's Avatar
50 psi here!
06 2500 MEGA! Sucessful Tranny Swap, Built Trans, Twins, Sticks, Arson III, Smarty-TNT/EZ Stack! Dyno 8-15-09; 546 HP 1111 Torque "Opinions Are like A$$holes. Everyboby Has One!!"
05pscc is offline   Reply With Quote
Old 01-16-2009, 10:03 AM   #8 (permalink)
cummins freak's Avatar
I ran 45 to 50 lbs when I had my 315's and thye road great!
as for the gel'in diesel 911 time
1997, 2500 CTD. 4x4 LWB, ext cab, MODS-#100 plate, JL Machine 5x0.016 Injectors, 3kgsk, timing at 16*, Dave G. trans, , HTT killer B II 64/14, Custom DV's from weston!!! Mods soon to be- traction bars,head studs, marine gasket.
cummins freak is offline   Reply With Quote
Old 01-16-2009, 10:06 AM   #9 (permalink)
Smokin'
Hot Stuff's Avatar
I ran 50 in the front and 35 in the rear unless I was pulling a trailer or loaded. Then I'd run 50 in the rear also.
It's a 3/4 ton truck...............Why do people b!t(h about the ride? If you want a road sofa, go buy a chevy!!!! Solid axle front trucks were meant to ride nice! Just pickin on ya man!
'03 Black 2500 QC/LB 4x4, 6 speed, BHAF, 2" lift, black H2's, 35" BFG MT's, B&W turnover, Juice w/ Attitude, 5" str8 pipe, BD lift pump, spin on filters, Firestone bags
Ohio Coal Roller
Hot Stuff is offline   Reply With Quote
Old 01-16-2009, 10:26 AM   #10 (permalink)
Poor Man Built
Dreadnaught's Avatar
well this helps me, i am going to put 35's on the truck today.
2004.5 Dodge Ram 3500 4x4 4 door, Short bed, Auto, 315X70 R17 Hankook RF10's, Recon Cab lights.
Silencer MIA, S&B CAI, 5" Expandit TBE, DiPricol (EGT, Boost, Pyro), Edge J/A
Early 2000 Ford F-350 Reg Cab Lb Dually 2006 Headlights and Grille
AFE Stage 2 intake, DP Tuner (20, 40, 80, 140), Custom exhaust, ITP Over Boost Annihilator, Derale Atomic Trans Cooler, 5" turnout stacks
Dreadnaught is online now   Reply With Quote
Old 01-16-2009, 08:22 PM   #11 (permalink)
One step at a time
Harley27's Avatar
Believe me I dont care but the back end was hoppin at 50 unloaded so I dropped it to 45 and feels better. Dont make me come over there
Old 01-16-2009, 09:26 PM   #12 (permalink)
Smokin'
Hot Stuff's Avatar
Bring it!!!! HAHA............If you don't haul much or pull trailer much, drop it to 35 or so. That's all most of us run when empty. Rides great. almost as soft as a bowtie! Only more like a real truck!
Ohio Coal Roller
