Dually tire size?
What is the biggest tire I can put on the back of my dually without using bolt on spacers? I know they make slip on spacers but I would only be able tuse maybe 1/4" Thanks,
Silver 06 4x4 Mega Cab Dually, 5" TBE, 2" leveling kit, BFG KM 255/75/17, Top Gun front / Frontier Gear rear bumpers, Retrax bed cover, Amp Reserch Power Steps, http://profile.myspace.com/index.cfm...ndID=146489284 |
#2 (permalink) |
dito i am wondering the same thing
95 12v DRW 5 spd. custom 5x14 injectors.66mm hx50 timing 17.5. 4k gv springs, marine head gasket, 12 mm studs fullcut dv's. single 7 in stack.Gauges of corse. POWER PARTS ENGINEERING DD clutch. airdog 150. |
#3 (permalink) |
i just put a set of 255/85/16 maxxis big horn m/ts on mine. i used a 1/2" spacer between them. when it is on the ground unloaded it has 3/8" between the tires. they are 33.7" tall
1997 cummins 4x4 2500 e/c l/b sledpuller "Never Ending" DominatorDiesel.com ----- TurboPerformanceProducts.com 2004.5 cummins 4x4 2500 4 door l/b w/ SMARTY |
#4 (permalink) |
Over Fueled and Budget
![]() Join Date: Mar 2008
265/70/17's were tight on mine.
Early 04 3500 drw quad cab-6speed SBC fast coolers - 4x4 -S&B -fass 150-expandit 5"- FTE resonator -SMARTY-autometer C2 full pillar gauges- di-pricol rpg-Dragonslayer cp3-64/71/14-PDI manifold -Wicked 125's - $2 rail cap.
#5 (permalink) | |
#6 (permalink) |
I want to go big. Has anyone had any problems with 2" spacers between the rear wheels? Are the safe to haul/pull heavy loads? Thanks,
#7 (permalink) |
yes they were. the nut is to the end of the stud, but it does fit
#8 (permalink) |
Ive got 3.5" spacers between 40x13.50x17s with no rub, an i haul/tow stuff all the time with no problems....just take the outside tire off a retighten bout every 6000 miles
#9 (permalink) |
Thanks for all the feedback. I have been hearing alot of horror stories about hauling with spacers, but they were comming from people that don't use them. I will be putting new tires on my truck soon and was a little worried about saftey.
#10 (permalink) |
got a stupid question a buddy of mine has an older dually he said he was putting onbigger studs to hold on the spacers to be safer i guess didn't want to sound like an idiot i said okay right on.... whats he talkin' about anyways ? possible?
06' QC 4x4 Dually. hell bent 2" leveling kit. 55 gallon under bed titan tank. Fierstone Air bags with comp under frame and in-cab control . Once my warranty runs out i plan on adding stuff but unsure of what yet. |
#11 (permalink) |
Some guys have gotten 285's to fit with a 1/4" spacer. but they don't recommend towing heavy.
06 Megacab dually 5.9 Auto, Diprocol Gauges, 5" turbo back FBD exhaust w/ muff,AFE Stage 2 w/PG7 filter, Smoked Recon tail, cab, brake lights and the Smarty ACDC |
#12 (permalink) |
I used 2 inch spacers on my Chevy Dually and towed heavy all the time. With the dodge I can run the same tire size as far as the 265 part with no issue. I run 265/70/17 Cooper stt with just a smidge of room left when loaded with my 30 ft corn pro loaded. I should get a 1/4 inch spacer next time around, but I am going back to Mastercraft Ct next tire purchase. I hate my STT's.
Hired Gun 2007 6.7 Automatic 6 speed DRW Smarty, 5 Inch Magnaflow turbo back
