Old 01-12-2009, 04:04 PM   #1 (permalink)
mstordahl's Avatar
How long are 19.5 and 22.5 tires lasting?
Stock tires are almost worn, and I am thinking of going to 19.5" or 22.5"; just wondering if anyone has gone through a set or has any idea how long tires of this size are lasting?
I want to get some "real world" numbers before I take the plunge. Truck is mostly highway drivin' with some towing.
Thanks in advance.
06.5 3500 4x4 QC DRW LB, Laramie J, 5.9ISB, 48RE, M.E. pipe, 5X24" tip, ISSPRO gauges, Smarty Jr
mstordahl is offline   Reply With Quote
Old 01-12-2009, 04:11 PM   #2 (permalink)
lobsterman04's Avatar
Originally Posted by mstordahl View Post
Stock tires are almost worn, and I am thinking of going to 19.5" or 22.5" and just wondering if anyone has gone through a set or has any idea how long tires of this size are lasting? I want to get some "real world" numbers before I take the plunge. Truck is mostly highway drivin' with some towing.
Thanks in advance.
If we could keep the nails out of the tires they might last longer. But on our semi's the last any where from 50'000 to 100'000. steers and lift axles last the longest. but i have no idea how long 22.5 will last on a truck that weighs 10'000lbs less and doesn't regularly pull 45-65 tons.
99 2500hd quad cab long bed,4.10, white n grey 2tone. BHAF,5in dual turn outs, boost guage,airdog150, 150sticks, Adrenaline, 57mm s300, masta performance transmission, ATI convertor. THANKS TO COAL TRAIN DIESEL PERFORMANCE U.S. Air Force 3E8X1. EOD.
lobsterman04 is offline   Reply With Quote
Old 01-12-2009, 05:09 PM   #3 (permalink)
my 99 3500 had 22.5s an probly 120,000 on the tires when i sold it an they looked new! they ride terrible compared to a regular pickup style radial but they last forever
Devilman is offline   Reply With Quote
Old 01-13-2009, 04:28 AM   #4 (permalink)
Performance's Avatar
I know of some guys with close to 30,000 miles on the 22.5s with no signs of wear. I personally have 15,000 miles on mine and they look brand new. I also don't have a problem with the ride or balance. The ride is a little firmer than stock, but it's really good for a 16ply tire. These tires are rated for 150,000 miles on a road tractor, so they will more than likely dry rot before you could wear them out.
2006 DODGE RAM 3500 - Silver, Reg. Cab, 4x4, Dually, 6spd, Quadzilla X2 Race Module, CFM+ Intake, AEM Workhorse Intake, Banks Monster Dual Exhaust, MBRP Cat. Delete Pipe, Isspro Gauges, Air Horns, ReadyLift Leveling Kit, 22.5" Classic Alcoas, 255/70 Sumitomos.
Performance is offline   Reply With Quote
Old 01-14-2009, 12:19 PM   #5 (permalink)
Perfornance you say these tires are rated for 150000 miles
can i get them in a winter tire or slightly aggresive pattern
something like a silent armor from goodyear. if not what would you recomend instead.
thanks in advance
06' QC 4x4 Dually. hell bent 2" leveling kit. 55 gallon under bed titan tank. Fierstone Air bags with comp under frame and in-cab control . Once my warranty runs out i plan on adding stuff but unsure of what yet.
leegal is offline   Reply With Quote
Old 01-14-2009, 12:37 PM   #6 (permalink)
Michelin XD2's are an AT tire basically.
08 Mega Laramie 3500 4x4, 22.5" Alcoas, 4.56 R&P, Firestone Ride-Rites, B&W hitched, Mag-Hytec covers.
Fool Injected 01 Jeep TJ, 510 hp
Kelso is offline   Reply With Quote
Old 01-15-2009, 03:43 AM   #7 (permalink)
thanks in advance
Yes, the 22.5s are rated for 150,000 miles on a semi at full tire pressure. There are many different tread patterns available. Michelin XD2's, like Kris said, are an AT. So are Sumitomo 908s. You will want a traction tire instead of a steer tire in a 255/70.
Old 01-15-2009, 03:57 PM   #8 (permalink)
thanx
thanks for the help
another question i have is are these tires as good wearing
if i used the 19.5 inch instead or do i need to get them in a 22 or 24 like the big rigs to get good mileage out of a set
Old 01-15-2009, 03:59 PM   #9 (permalink)
Poor Man Built
Dreadnaught's Avatar
we had a driver put a nail through the sidewall of a drive at 135k, and the company that put the replacement on put a new tire on cus it matched so good. michelin 255 70 22.5
2004.5 Dodge Ram 3500 4x4 4 door, Short bed, Auto, 315X70 R17 Hankook RF10's, Recon Cab lights.
Silencer MIA, S&B CAI, 5" Expandit TBE, DiPricol (EGT, Boost, Pyro), Edge J/A
Early 2000 Ford F-350 Reg Cab Lb Dually 2006 Headlights and Grille
AFE Stage 2 intake, DP Tuner (20, 40, 80, 140), Custom exhaust, ITP Over Boost Annihilator, Derale Atomic Trans Cooler, 5" turnout stacks
Dreadnaught is offline   Reply With Quote
Old 01-16-2009, 03:53 AM   #10 (permalink)
thanks for the help
The 19.5s will wear good too and maybe someone will chime in on a mileage quote, but you can't beat the 22.5s as far as wear mileage. I guess it just all depends on how much you want to spend. Price wise new, they are about the same though.
Old 01-16-2009, 10:09 AM   #11 (permalink)
Poor Man Built
i got 40k on my trailer tires that are 19.5's still have 90% tread left on the rear axle and 93% on the front.
Old 01-31-2009, 02:33 PM   #12 (permalink)
rollinsmoke05's Avatar
a guy that works us his dad drives a big truck and he says he get at least 240000 on michlins but he says he is going to a dunlop because there suppose to be better i don't notice to much ride difference and my fuel mileage on the road is better. just .02
05 3500 4x4 6 spd, needs injectors, turbo, and clutch. So that means it is broke down
96 3500 12 valve auto 2wd isspro guages, big honkin filter, st8 w/6" tip, pretty much stock afraid of the the tranny but like the 18 mpg www.myspace.com/rollinsmoke05
rollinsmoke05 is offline   Reply With Quote
