tire pressure light??
Just got a set of BFG KM2's. Tire shop put 55 lbs all the way around but my tire pressure light stays on. What pressure should I run to get it to stop. The tires say 65 lb max on the pressure??
#2 (permalink) |
Tire pressure
With the light load switch. The tires should be set at 45psi rear, 65psi front. With high load switch the tires are set at 65psi front 80psi rear. Then drive a few miles and the light will go out.
2008 2500HD 6.7 6 spd manual limited slip 3.73 gears, 5" SS TBE, XRT, egr gone,South Bend 3600 DD, AIRAID Intake,ISSPRO Gauges, Rugged folding cover, stainless nerf bars, 3" bull bar, Nitto terra's 285/70/17 |
#3 (permalink) |
Light load switch
This is a reset button .TO GET THE LIGHT LOAD TO LITE first you need to get the max tire pressure in all 4 tires.and the low presure light needs to be out you mave have to drive it 10-15 minutes.Then turn the key switch to run postion not starting just run and lower all 4 tires down to 55 in front and 45 in the back then push the switch and the light load should stay solid .this worked on my truk 08 Dodge 2500 Diesel |
