Old 01-07-2009, 10:40 PM   #1 (permalink)
Hummer Wheel Help
Just bought some H2 wheels and I want to run 37's on the wheels. I want to run the Toyo 37 x 13.50 17's. I think the backspacing on the H2 rims is 5.5, is that correct?
I am not going to be running a lift. I am going to put Thuren Suspension with the Carli leafs in the back. I think the leafs and the suspension move the axles a little bit so that the 37's don't rub (Carli says that on site).
The Toyo's are 13.50 wide so I am worried about them hitting the bottom of the fender on top being I think they will stick out past the fender, I'm wondering if they will hit the fender or my fender flares which stick out about 2 1/2 inches? Any thoughts?
Its for a 2007 2500.
Thanks
MDRW is offline   Reply With Quote
Old 01-07-2009, 10:59 PM   #2 (permalink)
I would be a little concerned with running the h2 wheel with the 37" toyo if you drive it hard.I have seen them break on the h2's with the lil BFG 315's
Bob
05 2500 4x4 Carli Dominator 3.0 Suspension Baja proven
94 2500 4x4 Carli performance 2.0 with full leafs
90 wrangler injected locked and caged crawler
bob4x4 is offline   Reply With Quote
Old 01-07-2009, 11:24 PM   #3 (permalink)
Break?
Bob
What did you meant by break, that doen't sound good.
Old 01-07-2009, 11:31 PM   #4 (permalink)
The center section breaks
