Old 01-07-2009, 05:42 PM   #1 (permalink)
cowboyupcash's Avatar
i need some info for h2 wheels
how much of the center do i need to rotor out to fit my 97 2500 dodge
97 cummins 12v with 5in turbo back dual stacks. a #5 fuel plate . an AFE st2 air intake system 3 gauge pod ,370 marine injectors,ddp full cut delivary valves,fass 150 fuel system . thank stahl diesel , jefferson state diesel and performane innovation transmision.
cowboyupcash is offline   Reply With Quote
Old 01-07-2009, 06:41 PM   #2 (permalink)
Super Moderator
LaMoparPower's Avatar
Moved for better exposure!
96' CCLWB 4x4, 22's, blacked out.... still has factory cat and muffler! its a work in progress
Big Thanks to Wally At FTEDiesel!!!!!
Enter the FTE FASS giveaway HERE!!!!!!!!!!!
LaMoparPower is offline   Reply With Quote
Old 01-07-2009, 07:38 PM   #3 (permalink)
MI Chapter President
IC-Smoke's Avatar
Im not sure about your 97 but this info should work, just measure the OD of your hub and you will know.
links:
2004 Dodge Ram 2500 4x4 H2 Wheel Mod and Install
H2 wheel and tires installed on 3rd generation Ram 2500-3500 SRW - TowRig Forums
hope this helps!
Ian
IAN COLEMAN - President Great Lakes CUMMINS Crew
1990 W350 4x4 LE std cab auto Project Restoration
2001 2500 4x4 3rd gen head, Twin Turbo, DTT trans, Monster pump
2006 2500 4x4 Smarty JR, H2's, B&W, AFE, 5" exhaust, meyer plow
IC-Smoke is offline   Reply With Quote
