Old 01-06-2009, 06:23 PM   #1 (permalink)
rileysack's Avatar
315's on stock 2nd gen wheels
does anyone know if 315's will fit on stock 2nd gen wheels? and if so do they rub on a truck with a leveling kit?
1995 12v Reg. cab long box, TC/shift kit, 4" straight piped exhaust, aem cold air intake, bully dog gauges, plateless/boost elbow, leveled with 315 BFG's.
rileysack is offline   Reply With Quote
Old 01-06-2009, 09:51 PM   #2 (permalink)
black01qcsb's Avatar
they do fit. they will rub at full lock someone correct me if im wrong
black 2001 2wd qcsb goerend billet,4.10's, juice with attitude, 5in fbd turbo back, black h2's 295/70/17 terra grap's 12k hid's 15.0 @91mph
black01qcsb is offline   Reply With Quote
Old 01-06-2009, 09:59 PM   #3 (permalink)
JST42LN's Avatar
305/70 on stock 02 rims rub on lower control arm only at full lock
2002 2500,auto,power puck,boost,transtemp, pyro, fuel pressure,MWFI VP, 8'6'' fisher plow, Airdog 100
JST42LN is offline   Reply With Quote
Old 01-06-2009, 10:00 PM   #4 (permalink)
Kansas Cummins Crew
moparpower1985's Avatar
Nope, I'd say that's about right.
2008 Crew Cab, Debadged, G56/3.42's, Edge Juice w/ Attitude, Exhaust, Intake Baffle Removed, 5.9 Air Filter, High Idle (pto) Feature, Valair Nodular Dual Disc, Cobra 29 WX, Ramsey 8000#Ind. Winch, 2.5" Spacers Front, 2" Rear Blocks,and ProComp 35/12.50/17's
Proud U.S. Army Soldier-21EVisit our Kansas Cummins Crew!
Click here >
http://www.cumminsforum.com/forum/ka...mins-crew.html
moparpower1985 is offline   Reply With Quote
Old 01-07-2009, 02:41 AM   #5 (permalink)
What about without a leveling kit???
2001 2500 6speed! Mods! Too many
kman9090 is offline   Reply With Quote
Old 01-07-2009, 02:54 AM   #6 (permalink)
Was A President
Garrard8's Avatar
I have 315s and a leveling kit and mine rubs some but its not hurting anything.If I was to turn to the right and drive around for a few hours while it scrubed then it might be a problem.
2001 2500,Auto,AD150,Drag Comp,Jammer100s..
Garrard8 is offline   Reply With Quote
Old 01-07-2009, 03:33 AM   #7 (permalink)
I don't think I would try it without a leveling kit
08 laramie mega cab 6.7 some goodies. 07.5 laramie quad cab some things fell off
torquey is offline   Reply With Quote
Old 01-07-2009, 05:30 PM   #8 (permalink)
They are too wide for the 6.5" wheels on the older trucks.
Jason
2001.5 Ext. Cab Short bed 4X4-315 BFG AT's/AEM HD intake/MBRP 4"/Silencer ring M.I.A/Raptor 100/new VP44/Mag deep trans pan/Edge EZ/RV275's/Quad Commander/Kool-Vue power/heated tow mirrors
JasonY is offline   Reply With Quote
Old 01-11-2009, 08:54 PM   #9 (permalink)
I agree with Jason. I put 315's on my truck on a 16x7 Alcoa wheel and it is wearing the centers out real quick. I was told that it would but I was to hard headed to listen. I run the air pressure as low as I am comfortable, about 30 psi in the back and a little more in front.
I have the 2" leveling kit and no issues with rubbing, just had to take the mudflaps off the front b/c it was going to rip them off. hope this helps.
Adam
1999 Dodge 3/4 ton. 4x4, 5spd, edge juice/w attitude, smarty, hx-40, 7x.010 injectors
WVU Dodge is offline   Reply With Quote
Old 01-12-2009, 01:44 AM   #10 (permalink)
Thumbs up pro- comp extremes
315-70-16 on my 1994 my other set 315-70-17's did rub, went to Carli Suspension's control arms! no problem!
1994 12 valve 4X4 2500 Loaded Carli Suspension featureing 3" Kings Full billet Suncoast trans converter & flex plate HX 40 370 injectors -Snow Performance Meth h20 injection- gov springs- ATS manifold- AFE sock 315-75-16 Pro-Comp Extremes Wilco
Grumpy John 4X4 is offline   Reply With Quote
