285/75/R16's
Im gonna put some 285's on my 01 4x4...curious if you guys know of a different speedo gear that i would have to put in my tranny or whatever? How far off would my speedometer be if i didnt change anything. Just curious any info is helpful. Thanks.
01 2500 4x4 CTD QCLB, Edge Ez, silencer MIA, cut off stock exhaust, BHAF, AFE Bladerunner, Air Dog 100, RV275's |
#2 (permalink) |
it might be off 2 or 3 mph its not a big enough deal to get a gear to correct it
black 2001 2wd qcsb goerend billet,4.10's, juice with attitude, 5in fbd turbo back, black h2's 295/70/17 terra grap's 12k hid's 15.0 @91mph
#3 (permalink) |
I got 285 and it's a very minor difference.
2000 short, 4x4, 6 speed, 12.25" DD Valair, S.O.VP44, AEM Brute Force HD, FBD 5" with 6" tip, ADRENALINE!!!, AirDog II 165, AutoMeter Cobalts, 35" Mud Grapplers on 18" Black XD Diesels |
#4 (permalink) |
The '01 is all electronic you can not change the speedometer ratio by swapping a speedo gear. Only way to do it is to reprogram the PCM. Some of the programmers (Smarty) can reprogram the PCM for different size tires. Otherwise you'd have to take it to a shop to get it reprogrammed.
Alex K. '01 3500 QC 4x4 NV5600 HO. Stock for now. BHAF, no silencer ring, muffler delete. WANTED: '98 12v 3500 QC 4x4 5spd 3.55 gears |
#5 (permalink) |
Since the speed signal comes from the rear axle speed sensor and the wheel speed senders up front, the tire size shouldn't effect the speedometer. Mine is off ~6mph from my GPS at 65. Which seems to be normal since i havnt owned a vehicle that the speedo is actually dead on accurate. Jason
2001.5 Ext. Cab Short bed 4X4-315 BFG AT's/AEM HD intake/MBRP 4"/Silencer ring M.I.A/Raptor 100/new VP44/Mag deep trans pan/Edge EZ/RV275's/Quad Commander/Kool-Vue power/heated tow mirrors |
#6 (permalink) | |
#7 (permalink) | |
![]() Wasn't thinking far enough into it ![]() Jason
#8 (permalink) |
This website right here should help you out...... Tire Size Calculator
01.5 2500 QC 4X4 6spd, DRAG COMP, KENNY DD CLUTCH, Hardened Output Shaft, RSD 5" exhaust, AEM Bruteforce, FASS 150/150, HTT Exhaust Manifold, ISSPRO (FP, boost, pyro), Thanks to James at Rollin Smoke Diesel.... |
#9 (permalink) |
SHOOTIN FOR 550HP!!!
![]() Join Date: Nov 2007
My Edge says i have the usual and expected 5mph difference with the 305's but the Garmin says its right on....
01 2500 4X4 QC LEVELED 35's on 17x10 KMCs: BHAF, JUICE(HOT), 150hp FIRESTORMS, 5" FBD STRAIGHT PIPED,J-HOOK, DTT VB, TCS 89% CONVERTER, BILLET SHAFTS, FDB BUILT TRANNY, HOLLEY PUMP, KIMBER 1911 SECURITY SYSTEM THANKS TO FARMBOYS DIESEL, WICKED DIESEL WANT: 2500 5.9L 4x4 MEGA cab, handshaker, 6"lift on 37's, FBD 5", Smarty, gauges www.myspace.com/74212921 |
