Old 12-04-2008, 12:16 AM   #1 (permalink)
john5mt's Avatar
13.50's on an 8.5" wheel
will 13.50's fit on an 8.5" wide wheel?
2001 3/4 QCSB 6spd HO 54Block 3.55's 35X13.50's Toyo At's, 18X9 +18 XD Hosses, Sky Jacker leveling springs, EdgeJ/AHot, ddp 150's, BHAF, 'SSI' 3rd gen Adjustable TB and Steering Stabilizer, AirDog 150 w/Vulcan DSV, Boost Elbow, Silencer Ring MIA, BIG BRAKES
john5mt is offline   Reply With Quote
Old 12-04-2008, 10:46 AM   #2 (permalink)
Gixxer_750's Avatar
yeah, you'll be fine...i had 14's on an 8" wheel and it was fine...actually protects the wheel a little bit:thumbsup
2001 4x4 - ACDC ..."i've got gauges so i'll race ya..."
Powered by FBD
Gixxer_750 is offline   Reply With Quote
Old 12-04-2008, 12:14 PM   #3 (permalink)
oldsmobiledave's Avatar
Curious
so then please explain why tire manufacturers do not recommend a 14" wide wheel on an 8" rim. I bet not many users would recommend that combination.
2004.5 Quad Cab 2500 4x4 auto VA C3.2 Carli Suspension
2005 Reg Cab 1 Ton Dually 4x4 auto Smarty Powered
Finding Oil & Burning Diesel
oldsmobiledave is offline   Reply With Quote
Old 12-04-2008, 12:17 PM   #4 (permalink)
TECH SPECIALIST
mathews8pt's Avatar
How tall of a tire you plan on runnin. The more sidewall the better off you'll be tryin to put it on that wheel. I have 33x14x16 boggers on my toyota, and i couldnt put them on a 8 inch wheel, had to find a 10 inch set.
2000 QCSB, built auto, P7100, 131 dvs, 4gsk, .084 lines and tubes, 7 x .014s, 22*s, maxspool 2.5 cam, 110# valve springs, 125ft lb head bolts, 66/74/.9
ohiocoalrollers.com
mathews8pt is offline   Reply With Quote
Old 12-04-2008, 04:42 PM   #5 (permalink)
AUTOBOX TRANSFORM!!!
SkinInc69's Avatar
I ran 33x13.5-20's irocs on my old ZR2 jimmy on 20x8.5 Rockstars. The tread doesnt sit as flat on a skinny rim and curves causing you to wear out the center of the tire faster especially when towing. I know a guy that ran 38.5x16-15's on 15x8's. The tread had a crazy round contact patch but he didnt care that the centers wore out fast.
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance BLACK MAXX, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
Old 12-05-2008, 03:51 PM   #6 (permalink)
Exactly. I think it's fine if you do a 37x13.5 on a 17x8.5 wheel (that's what i plan on doing). But a 33x13.5 on say a 20x8.5 wheel would probalby look and function like crap.
2008 2500 6.7L, G56, 4x4, quad cab, short bed - 5" Expandit TBE w/ muffler, S&B intake, Shibby EGR & cooler delete, Valair 12.25" ceramic dual disk, Smarty 67, EV2 EGT gauge.
schloe is offline   Reply With Quote
Old 12-05-2008, 07:33 PM   #7 (permalink)
Gixxer_750's Avatar
why do lift maunfacturers say only 35's will fit with 6" of lift...? it all depends on what you're doing w/ the rig...my 14" wide tire worked just fine on an 8" wheel, even when run at 7 psi (didnt pop the bead)...as far as ride, it did just fine...he's just asking a question and im giving a real-world answer
Powered by FBD
