Old 12-03-2008, 04:15 PM   #1 (permalink)
Is it possible
Is it possible to safely run a 35in tall tire on the stock rims of a 2nd gen 2500 with a leveling kit? Do they make a tire thats 35in tall but wont be to wide for the stock rims and stick out under the truck? Also what kind of leveling kit is the best bang for your buck? I was looking the readylift level kit but I have heard that spacers are bad so should I go with a spring kit?
dodge17 is offline   Reply With Quote
Old 12-03-2008, 04:33 PM   #2 (permalink)
koonswala's Avatar
i have 35s and they rub just a little at full turn with my leveling kit. but they are 13.50 wide. the spacing will make them stickout
comma to da top 05 cat mia, aero, smarty, blacked out
and needs a sundial to be timed.
Poser club member #2
koonswala is offline   Reply With Quote
Old 12-03-2008, 08:54 PM   #3 (permalink)
Cummins FTW's Avatar
35's and a 12.50 tire will work good with a leveling kit.... And yes 35's will fit on the stock rims I believe as long as there 8in wide
05 BLK'd Out 2500 CTD 4x4 Auto,.. Full Dipricol's 4' TBE AFE Stg.2 Intake CFM Smarty@Revo #3 398/747 @ Spring Fling '09
97
BLK 2500 CTD 4x4 5pd, 4'TBE, Pump Mods w/ 0 plate, Haisley Puller w/billet input
Cummins FTW is offline   Reply With Quote
Old 12-03-2008, 11:40 PM   #4 (permalink)
Some tire manufactures put the info for what size rim they recommend for the size tire you are using.
cksh8me is offline   Reply With Quote
Old 12-03-2008, 11:47 PM   #5 (permalink)
Gixxer_750's Avatar
you'll be fine w/ the leveling kit...i run 35x12.5's stock...as long as the wheel is 8" wide, you'll be fine
2001 4x4 - ACDC ..."i've got gauges so i'll race ya..."
Powered by FBD
Gixxer_750 is offline   Reply With Quote
Old 12-04-2008, 06:09 PM   #6 (permalink)
Cool thanks for the help guys
