SNOW PERFORMANCE TOYO MT 295's vs. 35's...
Wanted to get everyones opinions. I know for snow usually a narrower tire works best. The OEM BFG long trails are terrible in the snow. My wifes car does better than my truck until I put it in 4x4. On my 06 CTD, same issue, when I swapped tires I was amazed at how much better the truck was in the snow. On the 06 I was running 295/70/17 Toyo MT's. ON the 08, I woudl like to run 35x12.50/17 Toyo MT's. What do you guys think? Think they will be as good int he snow as the 295's, or am I going to regret getting suck a large wide tire? I travel alot in the winter to snowmobile, and when the snow is flying I don't let road conditions stop me from making it up north, so I need a tire that will give me the perofrmance needed to make the trek. The difference between stock and the toyos on the last truck, was the difference betweena white knuckle nose to the windshield drive, vs. a cautious but confident drive. any help is appreciated.
08 6.7L MEGA 2500 SLT 4X4 68RFE l DIPRICOL OPTIX BOOST/PYRO/TRANS l KORE CHASE l FOX 2.0 RR l CARLI LINKS l CARLI RESEVOIR MOUNTS l TINTED l TS MP-8 l 5" TBE l EGR DELETE l TEKONSHA P3 l LINE-X l PE JACKRABBIT l AFE MEGA CANNON l SMARTY S67PoD l 285 TOYO MT l |
#3 (permalink) |
not toyo but i had 35x 12.5 nitto mudders and did fine...actually a million times better than the stockers period.
05 dodge 2500 4x4 quad cab sb srw 5.9, 6-speed, 3.73,airaid intake, and 4"free flowin exauhst, p-pup, 35" xtmt procomps |
#4 (permalink) |
Why a mudder? Honestly, I like the looks of the mudders way better than an AT. I honestly havent been impressed with any of the mudders I have run on my Jeeps in the snow, but the Toyo's IMO did very well on the old truck in the snow...figure I'll go with what worked well for me in the past.
#5 (permalink) |
most mudders arent sipped...toyos and the nittos happen to be...i loved my trxus mt's in the snow...the lug pattern shovels snow out and the sipes take care of the ice...try checking them out:thumbsup
2001 4x4 - ACDC ..."i've got gauges so i'll race ya..." Powered by FBD
#6 (permalink) | |
Trxus are nice, but I wouldn't run them on my truck, wouldn't mind trying them on my TJ though. Just haven't had great luck with wear on interco tires.
#7 (permalink) |
for snow you could always sipe the tires... but if you do that I'd be cautious about any burnouts you do because that can chunk the crap out of a siped tire I've heard
1990 D350 5-Spd . HX-35 Turbo. Silencer ring MIA. 4 inch straight pipe off the turbo into 5 inch stacks. AFC/Smoke/Full power screw turned some. Timing advanced. Grid heater delete. 2000 Ford Powerjoke Intercooler. Ground fuel pin. Amsoil 4510.
#8 (permalink) | |
#9 (permalink) |
Toyo M/Ts are great in the snow. However they are absolutely horrible in the ice. I'm wondering if I can get them studded.
1998.5 Dodge 2500 4x4 QC/SB 24V Cummins Diesel. 5 Spd. Espar D5. Dipricol FP, Quad ADR/Pulse, VP not tapped, AirDog FP150, 185,000 Miles. 3rd Gen TB&DSS, Lightforce 170s http://s148.photobucket.com/albums/s18/Duramax411/ |
#10 (permalink) |
Supporting Vendor
![]() Join Date: Mar 2006
Most OEM tires stink, that's a plain fact. I think in the lower 48, studding tires is illegal. Alaska and Canada allow studs though. If you want a tire to work on snow packed and icy roads, the rule is the more edges and siping, the better the tire will perform. Mud tires are usually poor performers on ice and snow packed roads. The best all around tire I've owned thus far for mud/snow/ice/sand/everything is the Cooper S/T. I'm running the Cooper STT tires currently and the S/T tires were much better on snow and ice. -Chuck
Proud Cummins Forum Sponsor since 2006 Specializing in AMSOIL everything ![]() Change your thinking, not your oil.
#11 (permalink) | |
nope. my audi had studs on all 4 corners here in colorado (and quattro, it kicked butt in the snow). a lot of people here use them.
2008 2500 6.7L, G56, 4x4, quad cab, short bed - 5" Expandit TBE w/ muffler, S&B intake, Shibby EGR & cooler delete, Valair 12.25" ceramic dual disk, Smarty 67, EV2 EGT gauge. |
#12 (permalink) |
Consider 285-75-17 Toyo Mt's. Taller and a bit narrower than the 295's. They do have a lower weight rating though.
'07 2500 SLT,5.9,reg.cab.,G-56, 4wd,8' Northstar popup 24/7. Carli,Defiant,Kore,Lorenz and MADS. |
