Old 11-28-2008, 08:06 PM   #1 (permalink)
ben762's Avatar
Location: Eureka, CA originally - Grand Forks, ND for now
Exclamation Dura Grappler stem fail
I have a set of Dura Grappler A/Ts on my truck. They've proven to be a pretty good tire but I had a hiccup with one of them today.
I aired up my tires to about 65 rear/70 front as I normally do (eta: I don't tow or haul... the truck is turning into a toy) and after some mixed highway and city driving, I heard a sharp "pfffsst" come from my front driver's side as I was coming to a stop.
The source was the stem, and while the tire retained about 30-40 psi, any manipulation of the valve stem caused more leakage. Fortunately, I was within a mile of home and limped home.
I got the tire restemmed and looked at and was given a clean bill of health. Aired back up to about 65 (playing it safe) and drove it home no problem.
The tires have about 5k on them now.. has anyone else had a problem with their Nittos failing like this? I hope mine was just an isolated incident.
2001, NV4500, 4x4, 3.55, Quad Cab/Short Bed (FS 2500, FASS, AFE Stage I, MBRP 4" Turbo-Back, Edge Juice w/Attitide)
Purchased June 07 as 2nd owner with 37007 miles on the ticker.
ben762 is offline   Reply With Quote
Old 11-28-2008, 08:09 PM   #2 (permalink)
strick69's Avatar
A valve stem failure is not the tires fault.
2004.5 2500 4x4, 48re
strick69 is offline   Reply With Quote
Old 11-28-2008, 08:13 PM   #3 (permalink)
lol. right
2003 Red Sport Auto 4X4, SmartyTNT-lvl.7-shift defuel OFF, Goerend-FULL billet,Airdog150,Rail Capped,Quad Commander,Optix Rail,JL 75HP inj.,Banks Technicooler,2007 head swap-cam-springs-pushrods-Oring, Edge EZ,Wicked stage 1 Cp3, HTT 62mm, ARP 625's @ 160 ft. LBS
slimerept is offline   Reply With Quote
Old 11-28-2008, 08:18 PM   #4 (permalink)
Danderson's Avatar
There's a huge recall of Chinese made stems out there. I'd pay another buck ea just to enable our factories to make us a decent stem. Definitely not Nitto's fault.
'07 2500 SLT,5.9,reg.cab.,G-56, 4wd,8' Northstar popup 24/7. Carli,Defiant,Kore,Lorenz and MADS.
Danderson is offline   Reply With Quote
Old 11-28-2008, 08:24 PM   #5 (permalink)
i have had valve stem failure too. Replaced with steel stem.
John 3:16, John 14:6. Mega Cab Dually G56 2wd, Dr. P. 110/220, exhaust cutout, Traction Bars, leveled, Gooseneck, Iggee seat covers, Tekonsha Controller, Opti Lube Summer Blend, Mopar Tailgate Spoiler, Rokktech, '03 KX250/310, '01 KX500, '82 Yamaha 465
Joe Reitman is offline   Reply With Quote
Old 11-28-2008, 08:35 PM   #6 (permalink)
ben762's Avatar
Thanks Danderson and Joe for the heads up
Sounds like a restem of the other three is in order... I knew I lucked out today and sure wouldn't want that to happen on a snowy interstate somewhere.
Old 11-28-2008, 08:36 PM   #7 (permalink)
strick69's Avatar
I had steel stems put in my new rims. Make sure they use a stem rated for the higher pressure.
Old 11-28-2008, 09:01 PM   #8 (permalink)
Cummins FTW's Avatar
ya with big truck tires metal sleeve valve stems are the way to go:thumbsup
05 BLK'd Out 2500 CTD 4x4 Auto,.. Full Dipricol's 4' TBE AFE Stg.2 Intake CFM Smarty@Revo #3 398/747 @ Spring Fling '09
97
BLK 2500 CTD 4x4 5pd, 4'TBE, Pump Mods w/ 0 plate, Haisley Puller w/billet input
Cummins FTW is offline   Reply With Quote
Old 11-29-2008, 01:46 PM   #9 (permalink)
Discount Tire Direct
Discount Tire Direct's Avatar
Where did you purchase your tires ben?
America's Largest Independenly owned Wheel and Tire Retailer
www.discounttire.com
Discount Tire Direct is offline   Reply With Quote
Old 11-29-2008, 03:04 PM   #10 (permalink)
ben762's Avatar
The tires were purchased at a Les Schwab. I might have gone a different route but I was home on leave and time was short...
Old 11-29-2008, 03:10 PM   #11 (permalink)
I would call them and see if the valve stems they sold you were from Dill. If they are, they should have some kind of replacement program in place.
Old 11-29-2008, 03:45 PM   #12 (permalink)
ben762's Avatar
Aha, thanks. I was looking around for any sort of name of mfg for the stem :thumbsup
