Old 11-28-2008, 11:59 AM   #1 (permalink)
Lawn & Landscape pro
piersonslawnservice's Avatar
widen my front end.
Ive been looking around for some front wheel spacers for my dually. I dont want to add- I want to replace my existing front spacer with a longer spacer. I cant find anything anywhere. I would like to go about 2in wider if possible. the tires are tucked in the fender so much...besides the f450 stance is what Im trying to achieve. I understand they have a wider front axle...but I was hoping to extend the front wheel spacer... anyone have any ideas? or point me in the right direction...
06 Mega DRW, SPS 62, SmartyTNT/MP-8, Goerend, DTT , AirDog, Wicked, BD E Brake, Diamond Eye duals, 5in intake, Byrd, Ranchos, Eagle alloys in Nitto A/T, Amsoil, Opti lube XPD
02 LB7 Duramax -GT Turbo, Fass, EFI tuned w/dsp2 / MP-8 / Predator(scan tool), Suncoast V, Magnaflow duals, Pro Comp w/ XAT, Ranchos/ 3in lift, Amsoil, 2 stroke/ Opti lube
piersonslawnservice is offline   Reply With Quote
Old 11-28-2008, 12:42 PM   #2 (permalink)
scottd53's Avatar
I got mine of ebay...got 4 1.5inch spacer for 180 bucks shipped..fit perfect..
01 2500 auto w/Edge Comp, Edge Jammer 125hp nozzles, Super B Special, DTT TC and VB, FASS 150/150, 5in straight to black 6in turn-outs, 6in AMSOIL filter , 7in lift w/ 38x15.5 Baja Claws, Autometer Gauges... EGT,Boost,Fuel Pressure,Tranny Temp
scottd53 is offline   Reply With Quote
Old 11-28-2008, 01:14 PM   #3 (permalink)
Poor Man Built
Dreadnaught's Avatar
he doesnt want that kind of spacer, a dually axle has a bolted on offset for the rim to keep it from rubbing with how it is shaped for a dually. he wants a longer offset part of the axle.
2004.5 Dodge Ram 3500 4x4 4 door, Short bed, Auto, 315X70 R17 Hankook RF10's, Recon Cab lights.
Silencer MIA, S&B CAI, 5" Expandit TBE, DiPricol (EGT, Boost, Pyro), Edge J/A
Early 2000 Ford F-350 Reg Cab Lb Dually 2006 Headlights and Grille
AFE Stage 2 intake, DP Tuner (20, 40, 80, 140), Custom exhaust, ITP Over Boost Annihilator, Derale Atomic Trans Cooler, 5" turnout stacks
Dreadnaught is offline   Reply With Quote
Old 11-28-2008, 01:16 PM   #4 (permalink)
AUTOBOX TRANSFORM!!!
SkinInc69's Avatar
I bought 4 1.5" billet wheel spacers with the nuts for my truck which I never ended up using because I am going to put wider wheels on. I paid $320US for them but won't want that much since they are just sitting in my shelf. PM me if your interested. I have been meaning to put them in the classifieds.
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance Hot Damn 175 ATT, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
Old 11-28-2008, 01:24 PM   #5 (permalink)
correct...:thumbsup
Old 11-28-2008, 01:27 PM   #6 (permalink)
Poor Man Built
i know, i was lookin for the same thing for my old ford. good luck finding anything. you may end up with spacers.
Old 11-30-2008, 08:18 PM   #7 (permalink)
You may end up with tires rubbing the front bottom of the fenderwell when turning, due to tires kicked out further.
John 3:16, John 14:6. Mega Cab Dually G56 2wd, Dr. P. 110/220, exhaust cutout, Traction Bars, leveled, Gooseneck, Iggee seat covers, Tekonsha Controller, Opti Lube Summer Blend, Mopar Tailgate Spoiler, Rokktech, '03 KX250/310, '01 KX500, '82 Yamaha 465
Joe Reitman is offline   Reply With Quote
Old 11-30-2008, 08:21 PM   #8 (permalink)
anyone have this problem with stock tires?
Old 11-30-2008, 08:28 PM   #9 (permalink)
Was A President
Garrard8's Avatar
Find a good machine shop and let them make you a set.Are you planning on leaving the rear alone?
2001 2500,Auto,AD150,Drag Comp,Jammer100s..
Garrard8 is offline   Reply With Quote
Old 11-30-2008, 09:05 PM   #10 (permalink)
yes I was planning on leaving the rear. No machine shops local around my area. I would like to have some made... really dont want to add a spacer to what I have. but if I cant find anything else...I might have to. Im sure its not much different than going with a 10 lug conversion. Since that is like a small spacer...With my fender flares on the front it looks like the wheel sits so far under the truck. Anyone know where I could get some made?
Old 11-30-2008, 09:11 PM   #11 (permalink)
Lower Slower Delaware
cowbully's Avatar
There is a machine shop next to my dads shop. He says he can absolutely make anything out of steel or aluminum. IMO i would just slap a 1.5" spacer on there or get different rims with less back spacing! I highly doubt your gonna find what your looking for without getting it made and that is gonna cost BIG BUX
'96' 3500 4x4 12 valve Aurora 5K Turbo Heavy Pumpin P-Pump KDP Tabbed FASS BHAF Banks Twin Ram 6" Bull Haulers and a few aces in the hole NO FARMS NO FOOD
I.U.O.E. Local 542 "America is shaped by heavy equipment"
cowbully is offline   Reply With Quote
Old 11-30-2008, 09:14 PM   #12 (permalink)
thats what I was looking at doin if I couldnt find anyone whos done this before- getting a 1.5 spacer for each side and loc tite the interior nuts...
