Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 10-17-2008, 12:49 AM   #1 (permalink)
organized_confusion's Avatar
oil cosumption
i checked my oil at about 3000 km's and it was full, then when i check it at 5000 km's its about half way between the safe min and max lines, i ran rottella synthetic and CAT oil and it happens every time.
Does anyone know why this happens??or what i could try to stop it
2002 dodge sport 6spd HO, edge juice w/ attitude with hot code, 4" exhaust, exh. brake, banks quick turbo, AEM brute force, FASS 95/95 fuel pump, RV275's, pocket style flares, teflon coated rims, 03 trac bar conversion, Bi Xenon HID's, sound system
organized_confusion is offline   Reply With Quote
Old 10-17-2008, 02:49 PM   #2 (permalink)
CoalRoller's Avatar
Can you see any visible leaks in the engine compartment or under the truck? How many miles are on your truck? Mine still doesn't need any oil added between 5000 mile oil changes at 124000 miles. If you have alot of miles or idle time on your engine it is normal for it to use a little oil.
2002 6-speed, 5 inch straight pipe, Icebox, Edge Drag Comp/Smarty. Isspro pyrometer, mechanical boost guage & electric fuel pressure gauge. FASS 95, Valair kevlar/ceramic clutch...
CoalRoller is offline   Reply With Quote
Old 10-17-2008, 03:04 PM   #3 (permalink)
Dad
Administrator
Dad's Avatar
Cummins considers anything less than 1 quart in 1500 miles acceptable. Seems you are a bit more than that.
One thought, oil seems like to takes forever to run back to the pan after you shut it off. Do you check your oil in the morning after it has set all night?
A wise man speaks when he has something to say. Fools speak when they have to say something.
Dad is offline   Reply With Quote
Old 10-18-2008, 09:19 AM   #4 (permalink)
i check it after its been shut off for awhile, i have 190 000 km on the truck. last time i only had to add about half a quart or a little more to fill it back up at 5000 km.
