Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 09-16-2008, 07:54 PM   #1 (permalink)
DavesCummins's Avatar
Code P1689?
Hi, I am new to cummins forum and am looking for some help on my Grandfather's truck. It is a 1998.5 Ram 2500 24v and it dies on the road about every other week. It will start back up after sitting for an hour or so and sets code P1689 no communication between ECM and injection control module. I have used ALLDATA and checked the wiring harness for shorts or open circuits, and it says if all that check out then replace the ECM. The ECM is over $1000 from the dealer and I would hate to replace it if that is not the problem. Without checking it when it acts up, I cannot be sure that is the culprit. Any suggestions or help would be greatly appreciated. Thanks, Dave
2004.5 Ram QCSB AirRaid, TSTPowermaxCR, SmartyCR, MBRP 4" Turbo Back, Air Dog 150, Silencer Ring MIA, Stewart Warner Gauges, ATS Converter, Shift Kit, 2" lift, 315's on 06 wheels
DavesCummins is offline   Reply With Quote
Old 09-16-2008, 07:59 PM   #2 (permalink)
GA CUMMINS CREW PREZ
SOUTHERN SMOKE's Avatar
start off with checking the wires to the injection pump, usually when you get that code, the pump is going bad, and is about to die... i would start there....
CLICK---> GEORGIA CUMMINS CREW 2003 CTD SMOKIN' BLACK BEAUTY... QCSB 4x4 6-SPD...AUTOMETER BOOST, FUEL, OIL...2ND GEN 24V INTAKE HORN...EDGE J/A... B&W TURN-OVER... QUADZILLA R/P...RECON L.E.D. RUNNING LIGHTS... RECON LINE OF FIRE...33X12.50 COOPERS...SRT-10 HOOD...XM RADIO...THEY CALL ME SMOKEY...
SOUTHERN SMOKE is online now   Reply With Quote
Old 09-16-2008, 09:11 PM   #3 (permalink)
Tech Specialist
i agree, 9 out of 10 times the code means the pump is going bye bye. just my .02
Ramtech is offline   Reply With Quote
Old 10-09-2008, 06:45 PM   #4 (permalink)
I replaced the injection pump and it fixed the problem. Thanks for the help!
Old 10-18-2008, 07:42 AM   #5 (permalink)
jason's Avatar
I just got the code 1689 yesterday. I just had the fuel injection pump 2 weeks ago. I went and squeezed the connections on the harness for the pump and I found one that had just barely came out because when I squeezed it I felt it snap into place. So far so good no engine light and no codes.
2000,4x4, quad, 315procompAT's, XZT+ to big hoss level 5, banks high ram, banks wastegate, 100hp injectors, 4" exhaust,TAG, ranch hand bull nose, leveling kit, auto with hughes perf. TC and VB, pillar gauges- trans, pyro, boost, fuel press, BHAF,
jason is offline   Reply With Quote
Old 10-27-2008, 01:27 PM   #6 (permalink)
KWR
P1689 Problems
Hi, I am new to cummins forum and am looking for some help on my truck. It is a 2001 Ram 3500 24v and it stops for a second picks back up, kinda like a miss fire. The code is P1689 no communication between ECM and injection control module. This is my first Dodge and this problem dose not seem to be easy to fix by what I read. Any suggestions or help would be greatly appreciated. Thanks, Ken
KWR is offline   Reply With Quote
Old 10-27-2008, 01:36 PM   #7 (permalink)
Most of the time this code means your injection pump is going out. Do you have any problems with starting it, or lack of power on an intermittent basis? Mine had this code, wouldnt start at all, replaced the inj. pump now its fine.
99' 2500 AEM intake, 4" exhaust, Holley Blue, Edge w/ Attitude, Coaltrain tranny, Coaltrain 150 sticks, new II so vp44, trac bars, lock up switch, pyro gauge, stock turbo (need more air)
mathews8pt is offline   Reply With Quote
Old 10-27-2008, 02:17 PM   #8 (permalink)
KWR
I just purchase the truck last Thrusday and haulled about 80 rolls of hay with it Saturday. Starting has not been a problem. I have veiw the code and cleared it and drove the truck for miles and all at once the miss fires and the engine light appears back on the dash.
Old 10-30-2008, 09:10 PM   #9 (permalink)
jason's Avatar
What's your LP fuel PSI? Misfire huh? Do you have any power adders plugged in like a fueling box or a chip? If so unplug it and put your stock connecters back together, test your fuel PSI.
Old 11-17-2008, 08:37 AM   #10 (permalink)
KWR
Thanks for the responce but this last weekend I install a new injector pump and resloved my problems.
Thanks again.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
