| Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING |
no turn signal
I was driving to work this morning and discoverd that i didnt have any turn signals but the hazards work i've replaced the little relay thing in the fuse panel but still nothing could it be it the signal switch itself i already put a post in the urgent thread but figured i probibly put it in the wrong spot. any info will be much apriciated because i'm lost
02 2500 extended cab edge comp/drag box, K&N intake, 4 in MBRP exhaust, built trans, billet converter,HTS valvebody, autometer guages (trans temp, boost, egt, fuel press) bd frame mount lift pump, silencer ring moved out , lock-up switch |
#2 (permalink) |
turn on your turn signals and hold a finger ontop of the relay in your fuse box. make sure its your turn one and not the hazards. you should feel little clicking. if not its your relay again. check your fuse under the hood? could be the switch but VERY unlikely.
3.55s, 305/70/16s, MBRP 4''Turbo Back, #100 Full Forward, AFE ProDry Stage 1, DDP3s, Boost Elbow, AFC !MIA Silencer Ring !MIA, 55 PSI, DiPricol Boost/Pyro/Trans, KDP Tabbed, Built 47re, Farmboys Full Cut DVs, 3k GSK, ATS Quikspool |
#3 (permalink) |
If a piece has broken inside the switch it is pretty likely that the turn signals wouldn't work. The hazard switch supplies power to the relay, so if your hazards work then your relay works fine. The switch will supply power to left or right depending on how it is moved.
2003 Dodge Ram 2500 4X4, Banks Big Hoss Bundle, K&N FIPK, 5" Turbo back Expand-It exhaust, Goerend Full Built Trans, Smarty REVO, DIY Fuel Control Actuator Mod, FASS 150/150 and custom big line kit.ABS Brake Specialist-You've got questions, I've got answers. |
#4 (permalink) |
The hazard relay works i can feel it but not the blinker so youre tellin me that i probibly got a bad relay outa the box. i know its very possible but theres no other thinks to look at first.
#5 (permalink) |
no. The hazards and turn signals use the same flasher relay, so if either of them work (hazards or turn) then the relay is fine. If the turn signals aren't working then the signal from the switch isn't getting to the flasher relay to tell it to do it's thing.
#6 (permalink) |
Replaced signal switch now everything works fine, thanks for youre help guys.
#8 (permalink) |
you said it was fixed... but i had a similar problem.. it was the wire harness on the back of the spedo cluster, it wad wiggled loose and the blinker woud work the right way when the wanted to otherwise the left would make the right work and opposite for other side...
2003 Quad cab 2500.. my rig has a few things taken off and a few more added |
#9 (permalink) | |
just taking up space
(her's)2000 drw, quadcab lb, hx40/ht4c twins,180's, dtt, edge com, tst pm3, fuelboss, 6" miters (mine)2006 drw, quad cab lb, handshaker, 6" miters, smarty jr (sons)1997 quad cab, 5 sp, longbox, stock (shop)2004.5 quad cab, sb, stock
#10 (permalink) |
I would say very similar problem. The turn signal and high beam switch is all integrated into one.
#11 (permalink) |
left rear turn signal
I have a similar issue. Yesterday, my left rear turn signal stopped working. but the front flashes. The right side and all other lights are fine except for the left rear turn and left hazzard. I replaced all bulbs on the left rear side and the front one. Checked all fuses any ideas. thanks
2004.5 4x4, Quad, Dtt-Smart, II PS 62-12/ Gt 4202, ARP studs, F-1 Fass, Hot juice, Auto Meter- fuel, boost ,pyro, trans. |
#12 (permalink) |
I'll bump. 06 2500 mega cab that when I put the lever left or right, usually left turn does nothing and right works fine. Sometimes left turns on the right. If I put pressure forward as I turn left, it will work fine usually. So I'm guessing the problem is in the steering column shift lever component or something. Any advise?
