air conditioner problems - Dodge Cummins Diesel Forum
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
post #1 of 51 (permalink) Old 08-02-2008, 03:45 AM Thread Starter
occasionally I will have my air on and the air is barely coming out of the vent even when turned on high. however I can hear the fan blowing strong in the dash. sounds like maybe the vent doors aren't opening and closing right. air isn't coming out any vent anywhere. any help would be nice
kevinc is offline
post #2 of 51 (permalink) Old 08-02-2008, 03:47 AM
snackpack's Avatar
3rd gen? if so alot have had their mixing baffle/ damper come apart
02 QCLB 6 spd quad adrenaline/ pulse.. arp.. silver 62 .. s&b intake.. 150's.. southbend.. airdog.. arc flow.. dual 4" ..
snackpack is offline
post #3 of 51 (permalink) Old 08-02-2008, 03:53 AM
probly what happend to mine i know last year i would blow cold out drivers side and hot out passsenger not all the time just for a whiel then it would cool down
05 dodge 2500 4x4 quad cab sb srw 5.9, 6-speed, 3.73,airaid intake, and 4"free flowin exauhst, p-pup, 35" xtmt procomps
whiterocket5.9 is offline
The Following 2 Users Say Thank You to whiterocket5.9 For This Useful Post:
Bruner_t (07-17-2009), tmj0824 (06-21-2012)
post #4 of 51 (permalink) Old 08-02-2008, 03:58 AM
snackpack's Avatar
i'm not sure, but i think some would cut the air all but off, and some would dump heat and cool.
post #5 of 51 (permalink) Old 08-02-2008, 04:54 AM
ibcummin's Avatar
I cant remember if dodge trucks have a cabin air filter?? If it does, that would be a good place to start.
2005 RAM 3500 H.O 4x4 QUAD CAB LARAMIE
Gone but not forgotten
2016 Ram 2500 Tradesman Crew Cab 4X4
ibcummin is offline
post #6 of 51 (permalink) Old 08-02-2008, 07:34 AM
ynots57's Avatar
the mixxing door is a common problem on dodges. there is a linkage or something that comes loose that is suppose to acctuate the door
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is offline
post #7 of 51 (permalink) Old 08-02-2008, 09:27 PM
Tech Specialist
check to see if there is a difference when you switch from recirc to fresh air. If there isn't you probably have a busted recirc door. just my .02
Ramtech is offline
post #8 of 51 (permalink) Old 08-02-2008, 09:38 PM
YamYZ250F's Avatar
i got the same problem with my 06. thos last year it rattled really bad on high, i got that fixed and now it doesnt blow the air out like it should ive tryed all the settings and what sucks is its not longer under warr. anyone know how to fix this problem yourself? my dads 03 works just fine..
2014 2500 4x4 big horn with black out package 18x9 vision off-road rims 295/70/18 nitto g2's
YamYZ250F is offline
post #9 of 51 (permalink) Old 08-02-2008, 09:45 PM
I found that if you shut down the system, cycle from hot to cold or vice versa, then cycle the blend through all the positions, you relearn the body controll modual.
cjdave is offline
post #10 of 51 (permalink) Old 08-03-2008, 12:43 AM
my 06 had same issue with the door 2x where it would rattle or flap on high. Both those times were under warranty. But this past Thursday my a/c compressor went out. And I'm past warranty so it was $980! Ouch...
06 2500, Bullydog, quadzilla race module, Boost Fooler, AEM Brute Force Intake, CFM+ Intake, Silverline 4" Duals,POS Auto Meter Phantom Gauges, Airdog 150
dalton06 is offline
post #11 of 51 (permalink) Old 08-03-2008, 02:28 AM Thread Starter
thanks guys, i will look into it. and yes it is third gen. 2003
kevinc is offline
The Following User Says Thank You to kevinc For This Useful Post:
rllnsmk (04-07-2010)
post #12 of 51 (permalink) Old 08-03-2008, 02:54 AM
EAST TEXAS VP
Diesel_Nuts's Avatar
Mine blows warm air every now and then when I am hard on the throttle, but gets cold again after a few seconds. Always wondered what caused that. Anyways, good luck to you with the A/C.
Big Blue - SOLD....
Diesel_Nuts is offline
