Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 01-07-2008, 06:01 PM   #37 (permalink)
Why not just use your mirrors when backing up?
Shawn
2001 2500 5-speed edge-ez,275 inj.,BHAF,jacob e-brake w/shifter switch, isspro(pyro,boost,f.p.)mechanical gauges,Walbro lift pump 1/06
slim51015 is offline   Reply With Quote
Old 02-07-2008, 08:42 PM   #38 (permalink)
No.... how'bout DODGE fix the real problem instead of putting a BANDAID on it just to cover their butt in a lawsuit. They don't want to get sued and they know they have a problem; SO THEIR FIX IS TO WORRY THEIR VALUED CUSTOMERS TO DEATH WHEN THEY ARE TRYING TO LINE UP THEIR TRAILER!!!!!!! WHICH ANYONE WHO OWNS A CUMMINS WILL PROBABLY DO QUITE A BIT. HEY IT SOUNDS GOOD IF YOUR THE CEO; PROGRAM CHANGES DON'T COST A THING!I'm sure the moron who thought that one up got a great bonus!!!!
YEAH......they got me too! Amazing thing is mines an 03' and they still haven't fixed the problem. THANKS FOR LETTING ME VENT.......I FEEL A LITTLE SMIDGON BETTER. and no, I hang out the window.....after I scare everyone at the boat ramp to death. Dodge won't fix the problem and I look like the moron.
03' 2500 Quadcab 4X4 5.9 H.O. Upgrades cummin
Grey Mule is offline   Reply With Quote
Old 02-07-2008, 08:49 PM   #39 (permalink)
same thing happened to me when I had my 04.5, took it in for oil change, they told me there was a recall and explained everything, so I told them not to do it, well they did it anyway. when I told them to undo it they said it cant be undone. Man I could not stand that gamn horn going off. just have to deal with it, or unplug the horn? maybe?
07.5 Mega Cab 6.7, S&B AirBox 6spd auto 4x4 H&S 5" turbo back, BullyDog PMT, egr delete, Garmin GPS, Back up Cam,
turbodiesel5 is online now   Reply With Quote
Old 02-10-2008, 01:16 PM   #40 (permalink)
Originally Posted by Towtug View Post
Sorry you had that done with out your advisor explaining what was involved. The new 2006 trucks have that standard and when they do the flash, part of the flash is to disable the ability to accept the older version of software...
No going back! Sorry. I hate it to but have trained myself to use the brake just enough to still be able to back up to my trailers and keep the alarm from sounding off!!!
JOSH
Tried the hold the break on trick and it works great. Now I just have to program my brain to remember this trick. THANKS FOR THE TIP!!!!!!
Old 02-14-2008, 08:09 AM   #41 (permalink)
Once its done there is no going back to bad ur service advisor didnt tell you. We tell everyone not to do it.Very annoying
Mapel Valley Kennels LLC. is offline   Reply With Quote
Old 02-23-2008, 07:06 AM   #42 (permalink)
MCummings's Avatar
This is somewhat untrue and misleading.
DC Computers cannot "reverse flash" any vehicle. No flash, no program, no version. You can only get the "latest and greatest".
If the flash you had works great, and it gets reflashed, no amount of lawyers or cash will get you your old flash back. It is not possible through O.E. channels.
Merrick
'98.5 3500 2wd 6-speed
512/1021, 21MPG and 65 pounds of boost.
Hers,
'98.0 2500 4wd Auto, Lifted, Straight pipe, no plate, no afc, 38" Boggers, Viper alarm. 108K miles.
MCummings is offline   Reply With Quote
Old 02-23-2008, 11:24 PM   #43 (permalink)
Brewbud's Avatar
Does the horn still beep if the seat belt is on? I read somewhere that having the belt fastened would prevent the horn from blasting. Guess I will have to try it tomorrow.
Brewbud is offline   Reply With Quote
Old 02-27-2008, 08:10 AM   #44 (permalink)
My truck did this. Drove me crazy. I did the seat belt trick described on here and it stopped it. With door closed and ign. off buckle seat belt, turn ign. on wait for belt light to go out and buckle/unbuckle 10-15 times quickly, turn ign off and then turn it back on fixed mine maybe I got lucky. Naaaaah cant be that Not very lucky
2004.5 quadcab 4x4, 5.9 auto 4.10's, 35's, hypertech programmer, K&N, muffler delete, no cat, silencer delete, torque tube gutted
rescueu is offline   Reply With Quote
Old 08-22-2008, 08:01 PM   #45 (permalink)
thats pretty good Rescueu
Old 08-22-2008, 08:45 PM   #46 (permalink)
Tech Specialist
the last truck i worked on with this concern, i disconnected the driver's seat belt latch, built a jumper, problem solved. as long as the seat belt light was out, no nasty noise. just my .02 - good luck
Ramtech is offline   Reply With Quote
Old 09-22-2008, 12:05 AM   #47 (permalink)
Crude's Avatar
this seems counter productive? A fix like this causing owners to disable the seat belt warning? By the way chevy doesn't have this? How did they get away without it?
Crude is offline   Reply With Quote
Old 09-23-2008, 02:43 PM   #48 (permalink)
Why not install a relay that disables the horn when the door is open or it's in reverse or the seatbelt is undone or all of the above?
'00 Quad Cummins 4x4 Shortbox, Silver. From AZ to AB. Finally installed; Adrenaline (impressive) w/ Pulse (less so), Raptor, Dodge Steering Stabilizer, Luke's Link, Leer tonneau. Still to come; Mikuni MX-40 coolant heater, Tires...
JoeCanuck is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
