Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 11-09-2006, 08:58 AM   #25 (permalink)
donnie's Avatar
Iv received the notice about the recall twice.
Shortly after I got the first one, I had some work done by the dealer and they asked if I wanted the recall installed. Told them NO.
They have it on their computer that I have refused it.
If someone is assisting in the backing up of the trailer, consider investing in a cheapy pair of FRS radios.
Just a thought.
05 2500 Silver Quad .4 spd. w/ 3.73 gears. Isspro pyro, boost, tranny temp, FP gauges. Silencer MIA. Amsoil Dropin w/ Airraid MIT. Catback MBRP.
Bst Bilsteins
donnie is offline   Reply With Quote
Old 11-10-2006, 03:41 PM   #26 (permalink)
does anyone have this problem with a manual trans?
dieseljunkie is offline   Reply With Quote
Old 11-11-2006, 04:57 PM   #27 (permalink)
Tech Specialist
Towtug's Avatar
I have a buddies 06 standard shift truck in the shop and will check just to make sure im not fibbing to you but I dont believe it is on the 2006 standard shift trucks!!!
JOSH
2006 CTD MEGACAB 3500 4x4 AUTO Towing my Rockbuggy from one state to the next...
Stop By And Vote For ROTM
Towtug is offline   Reply With Quote
Old 04-09-2007, 07:08 AM   #28 (permalink)
That fix will work fine... As long as when you put the truck in park you leave the door open in case it shifts into reverse. If yo shut the door when it does it it's just gonna roll away without a peep.
RSWORDS is offline   Reply With Quote
Old 11-14-2007, 10:33 PM   #29 (permalink)
back-em up and no.... honk
A simple solution would be to splice a timed relay into the horn power or the door switch ?? Press of a button in the cab to temporarily disable signals or horn output..... Shouldn't be so difficult I would think
rgds,
Dave
Dave
2005 QC 2500 4x4 Cummins that thinks its a Harley....
Likes to mark its spot !
NewJoy is offline   Reply With Quote
Old 11-25-2007, 03:31 AM   #30 (permalink)
Slacker
ynots57's Avatar
The infamous local dealer was going to do recall while repairing rear leaking window. Lucky for me the idiots signed off on it and the flash was never done. Would you believe the #%@*'s installed a non-oem rear slider that costs 100's less, one that most glass shops wont even consider using on dodges. Gonna have talk about window next week, I'm pi$$ed
05 - 2500, 4x4x6 srw, 48re, aero, cai, other goodies
ynots57 is offline   Reply With Quote
Old 11-25-2007, 10:16 AM   #31 (permalink)
Rockwerx's Avatar
I would be ticked off also if they installed non-oem parts. Good luck with your "talk/yell" session with them!
2008 Ram 3500 Laramie Quad Cab 4x4 LB DRW 6.7 CTD 6Auto 3.73 LSD
EJA, EPP, MES, KAF, ABD, FHO, AFT, HIE, EBO, RWX
Parts keep falling off my truck...The latest in Blacktec technology added
Rockwerx is offline   Reply With Quote
Old 12-29-2007, 07:50 PM   #32 (permalink)
Hey just joined the site and going through some old forums. I remember when I made this mistake of having this done. My fix was just pulling the fuse on the horn. Sucks not having a horn, but at least it isn't honking everytime I get out!
jmartin1980 is offline   Reply With Quote
Old 12-29-2007, 08:28 PM   #33 (permalink)
maltrin's Avatar
Originally Posted by Towtug View Post
I hold just enough pressure on the foot brake pedal to turn the tail lights on and the alarm does not sound off.
If it is the brake lights coming on that makes it not honk the horn. Maybe, and It would be a pain in the , but maybe you could put a toggle switch that you can turn on when hooking up the trailer. Flip the toggle, and just leave the brake light switch engaged til you are done. Surely there is some wire you can tap and toggle it so that you can hit the switch while hooking up and turn it back off when you are done? OR toggle switch the horn wire?
maltrin is offline   Reply With Quote
Old 01-07-2008, 04:53 PM   #34 (permalink)
Breadman03's Avatar
I don't have that headache, but on my enclosed trailer, there is a seam on the front that I can line up in my rearview to get within one inch everytime, and from hitching daily, I can tell how far away the trailer is. Another trick is to make sure you are perfectly lined up by making sure you can see the same image of your trailer in each side mirror. You can back up until you are fairly close, then get out and walk to your trailer coupling. Look from directly over the coupling at your ball and see if it is pointing at your coupling. If it's pointed to the side, correct as needed. Just take it easy and feel for the light bump. Once you feel that, you'll need to come forward about 1 to 2 inches to line the ball up with the coupling and you're all set to connect. I do this daily, and I started out taking about 5 attempts until I got lined up. Now, it's almost always lined up on the first shot. My coupler lock on the trailer helps get me out to check. It has survived many a bashing by a hopeful trailer owner (4 times in the last year and a half) and I will never leave it alone without it. Mine is a Masterlock the basically has a "ball" that fits into the coupling and a plate that fits over the front and acts as a clamp to keep it in there.
03 3500 SRW 250 Horse 47re 4x4 QCSB
MBRP 4" turbo bak exhaust, Trac-Rac.
AMSoil, Amsoil oil, air filter
Breadman03 is offline   Reply With Quote
Old 01-07-2008, 04:55 PM   #35 (permalink)
bcollin3's Avatar
there is a code you can do to disable that... it involves the seatbelt, the door, and putting the truck in drive, reverse, and neutral in some sort of combo. My dads '06 3500 did the same thing and a ex cummins certified mechanic friend of ours turned it off that way. I will try to find out how he did it. and let ya'll know!
2001 - 2500 5.9 H.O. 6 spd. SWB - 4x4 - 4.10 gears - South Bend Performance Clutch - FASS 150/150 - FASS Draw Straw - 5'' turbo back straight pipe - Edge w/attitude - S&B cold air intake- Banks Ram Air Intake Manifold- Silencer ring MIA
bcollin3 is offline   Reply With Quote
Old 01-07-2008, 05:22 PM   #36 (permalink)
niedhogg's Avatar
And then you do the hokey pokey and...
Had that recall on my 04 too. Drove me crazy!
'07.5, 6.7L 3500HD 4x4 Megacab Dually, 6 Speed Auto, Line-X Spray-in Bedliner, Muffler MIA w/5" Stainless Tip
niedhogg is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
