Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 09-26-2009, 12:59 AM   #25 (permalink)
Hey ram2500 the dealer cost in my area is 120 or try (transmission parts usa) there price is about 50 bucks. If this is pertaining to the 1-2 shift hunt at light throttle or dealer service bulletin TSB 21-009-07 It would be wise to also get the governor pressure sensor as this more then likely is the problem, Its another 50 bucks but money well spent. Don't do like I did and trust the service bulletin or you will be taking the pan off again and 4 more quarts of tranny fluid.
04.5rockymountaindiesel is offline   Reply With Quote
Old 09-26-2009, 08:54 AM   #26 (permalink)
ok I'm going to order the Transmission governor pressure sensor and the Transmission overdrive & lockup solenoid because it looks they need to be replace together or at least thats how transmission parts usa has it listed. Does all this sound right?
2005, LB, quad cab,5 inch skyjacker 37/12.5/17, weld dunes, Diablo sport combo, Nfab steps.
ram2500 is offline   Reply With Quote
Old 09-26-2009, 12:40 PM   #27 (permalink)
Looks good........ Transmission parts usa lists the cable solenoid lock up under the pressure sensor the parts that are needed are the governor pressure solenoid part # 53396 and the pressure sensor part # 53397A good luck.
Last edited by 04.5rockymountaindiesel : 09-26-2009 at 01:15 PM. Reason: wrong additional part listed
Old 09-26-2009, 10:23 PM   #28 (permalink)
Thanks I guess I'll also add a filter.
Old 09-29-2009, 05:27 PM   #29 (permalink)
Hi All - First post on the forum. I have an 07 5.9 2500 4x4 with this same problem, I found the this site and the technical bulliten when it started to switch between 1st and 2nd. I've just scheduled my 3rd appointment with the local dealer to get this fixed. Everytime they say it's been fixed and tighted up the shifting bands, and for the first couple months it runs perfectly, but....
The truck is still under warranty so I'd like to get it fixed with no cost, but I'm almost to the point that I want it fixed and don't really care what the costs it.
You guys have any suggestions on what I should do?
Thanks,
Terry
telam is offline   Reply With Quote
Old 10-01-2009, 09:19 PM   #30 (permalink)
Just posting an update, I adjusted trans bands and replaced both governor pressure sensor
and overdrive & lockup solenoid followed by a new filter. Trans is now shifting normal. Thanks for the help
Old 10-29-2009, 09:58 PM   #31 (permalink)
BO's_06_Cummins's Avatar
bump for an all to common problem... anyone know if the TS shiftmaster helps this problem.. they say it eliminates gear huntin...??
06-2500-QC-4x4-Laramie---K&N-Diablo-Aero
Kore-BFG---FireSticks-CobraBlackChrome
BO's_06_Cummins is offline   Reply With Quote
Old 10-30-2009, 01:26 PM   #32 (permalink)
razorp's Avatar
i had similar problems and it was a valve body problem, not tranny, wouldnt shift until after redlining for a while i had to be really easy on it and just put around before it would shift
06, 2500, HD, camo seat covers, Silencer ring MIA, nitto a/t tires, leveling kit, rear ranchhand replacement, 4 inch straight pipe, 5 inch tip.
razorp is offline   Reply With Quote
Old 11-01-2009, 09:08 PM   #33 (permalink)
my 06 with 50K on it has the normal 1-2 search problems...i was told by the dealer when i bought it that the trans and the engine were covered under the powertrain/drivetrain warranty. my truck has never had a programer on it so is the trans really not covered?
2006 QCSB 4x4 5.9L..AFE, Smarty JR, muffler delete.
4U 2 NV is offline   Reply With Quote
Old 11-01-2009, 11:22 PM   #34 (permalink)
dodge_24's Avatar
it might be diff on the 3 gen but mine did that once and i checked the ground connections on the battery and they where loose thighten them up and it when away
maybe it will help u
straight pipe, S&B intake,edge comp EZ,raptor 100,isspro guages,recon fuel press,bully dog J hook,MBRP 4",Banks high ram
dodge_24 is offline   Reply With Quote
Old 11-07-2009, 07:36 AM   #35 (permalink)
EL WYOMING PRESIDENTE'
Giddyup5.9's Avatar
Governer solenoid is the fix for the 1-2 shuttle shifting on your 06
Projects - CTD rail project: On Hold, 68 D-100 Reg/short that needs a CTD
06 MCLB: BDTD/MP8/DDP90'S/ARSONIII/H11'S/HE351-A5K/5S TC/BILLET TRANS/AD165/4.5LIFT/20'S/35'S - 676hp. Thanks: Eric(ATS), Shane(Wicked), Danny(FTD), Tim, The BD Guru, Kenny and Levi-->
"Keep smoking people out, one day an angy prius owner will do a VERY QUIET drive-by on you!"
Giddyup5.9 is offline   Reply With Quote
