Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 03-27-2008, 09:11 AM   #1 (permalink)
CumminsPower09's Avatar
injector ?
I just got a 02 dodge about a week ago, and I have a couple questions and any help would be greatly appreciated. I just installed the isspro boost and pyro and i need to install the fuel pressure. I got it used and it came with no instructions. I know i need a banjo bolt but that is really all i know any help on where to install and how would be great. I am also looking at getting some new injectors with higher horsepower i dont know much about that either. By putting on new injectors say 75 horse with my 50 horse puck will that mean im getting 125 horse or will the injector override the programmer. And are there other upgrades i need to do before injectors. Sorry for the long post i just need a little help and guidance. Thanks
02 cummins 4x4 ext. cab,6 spd., Diablo power puck,K&N intake, Isspro boost, pyro, fuel pressure, single 5" stack, Custom Headache Rack For Sale $16000
CumminsPower09 is offline   Reply With Quote
Old 04-18-2008, 03:42 AM   #2 (permalink)
clc
clc's Avatar
On my '98 there were two 1/8" NPT brass plugs on the top of the fuel filter. I removed the one closest to the center (after the filter) and connected the fuel gauge there. On my '96 I drilled and tapped (1/8" NPT) the head of the banjo bolt on the fuel line at the injector pump.
The puck and the injector power increases may not add linearly but they will both add power. You may get more smoke with the pair than with either alone. It is likely that both will advance your timing so be even more careful about lugging the engine.
You should probably consider upgrading the air filter. I plan to put BHAF and 75 HP injectors on both of mine.
You are doing good by putting gauges on first.
You might want to upgrade your lift pump.
96 3500 4WD, 47RE, gauges; 97 3500 4WD 47RE, gauges; 97 3500 2WD 5-spd; all club cab. 98.5 2500 2WD SB, 5-spd, gauges, quad cab
clc is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
