Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 07-26-2008, 05:00 PM   #37 (permalink)
Wildcat, Thank you .
I tried it and it did not work but now I know what to do .
Anybody around Whitesboro Tx with a Smarty ?
Lester,
07 2500HD 5.9 , 3.73 rear end , Reg.cab, 2WD , 6spd man and bone stock
pacific23 is offline   Reply With Quote
Old 07-26-2008, 05:16 PM   #38 (permalink)
DieselFarmin's Avatar
some dealers will enable it for free. some won't. I got lucky
Inferno Red '07 2500 5.9 Quad Cab Big Horn 4X4. 3.73's Line-X X-tra over the rail, Stainless rockers, 285/70R17 BFG TA KO's and B&W gooseneck.
IAFF LOCAL 1897
DieselFarmin is offline   Reply With Quote
Old 09-05-2008, 08:14 AM   #39 (permalink)
We run a fleet of Dodge Cummins trucks in an oilfield service environment and extended idle is part of life.
Service hands need to stop for a few hours of sleep beside the road at times and at -40, you can't have the truck going into shutdown. (D'ya think!?)
Has anyone got a solution?
Thx,
Dan
GTR-Dad is offline   Reply With Quote
Old 09-05-2008, 05:07 PM   #40 (permalink)
Tech Specialist
WorkhorseDiesel's Avatar
GTR-Dad,
As long as you get the "high-idle" feature enabled on your trucks, you should be fine to idle as long as you want. In the 5.9L Cummins trucks, as long as the trucks idle around 1200-1400 rpm's, there isn't any issues with a Cummins idling for long periods. The only issues come up when the trucks are idling in the factory 800 rpm range. Idling at such a low rpm in cold weather invites problems. Now, if your fleet trucks are running the 6.7L Cummins, then you might have a serious problem. The DPF could cause you idling problems. Hope this helps.
2001.5 White 2500 Reg-cab • 4x4 • NV4500 • 4.10 • BHAFWALBRO GSL392Edge Juice + AttitudeVALAIR HD OFEScangauge II • 315 Cooper S/T's • Optimas • custom black grille & blue graphics • ** Diesel Fuel Treatment is here **
WorkhorseDiesel is offline   Reply With Quote
Old 09-05-2008, 09:06 PM   #41 (permalink)
What criteria must be met to get the elevated idle to come on.On my Ford I had a switch to turn on and the e-brake needed to be on.On my 5.9l with the Smarty 6spd will it elevate the idle only when its cold out?Will the idle be elevated all the time?Or do I need to do some steps to enable it?Thanks for any information!
2007 3500 5.9L DRW 6spd manual 4X4 QuadCab, S&B intake,5" turbo back exhaust,Smarty SW3 Revo Tune,Amsoil everywhere with bypass system,Line-X spray in bedliner,Back-Rack,SBC DD 3250 with .750 upgraged hydraulics, Stryker SR-490HP C.B., and Dual Firestik's.
HarkinsTransport is offline   Reply With Quote
Old 09-10-2008, 05:06 PM   #42 (permalink)
The new ones are all 6.7L... I'm looking for solutions to the DPF problem.
Thx,
Dan
Old 09-11-2008, 06:36 AM   #43 (permalink)
If you keep your idle up, it will keep the temps up, thus increasing your available idle time. Cummins put out a memo saying that it will take hours upon hours of idling to fill the dpf.
Ultimtely, the best way to deal with the dpf is to remove it.
John
'08 3500 Mega SRW 6.7 Auto
John Banks is offline   Reply With Quote
Old 09-11-2008, 08:12 AM   #44 (permalink)
Should I expect any ill effects other than a few more particulates in the air?
Thx
Old 09-11-2008, 08:16 AM   #45 (permalink)
Thx
there's a lot of good reading here on the benefits of removing the dpf along with the egr and associated cooler. No ill affects, only if you leave these items in place. The list of benefits are almost endless - cooler egts, less soot forced through the motor, increased motor longevity, a happier motor, increased fuel mileage, turbo response, exhaust brake strength, less weight over the front-end, etc. you get the picture.
John
Old 09-11-2008, 08:21 AM   #46 (permalink)
LOL! Thanks!
I'll search harder, but I know now what I'll find!
Dan
Old 09-11-2008, 08:57 PM   #47 (permalink)
for the high idol to work with the manual trans you will need to ground a pin on the ecm it is the 1 for the pto cant remember the number of the pin all you do is remmove the plug to the ecm and from the back side of the pig tail push out the plastic plug and and get a wire termanal plug from cummins and incert it in the hole you pushed the plastic plug out of and and hook the other end of the wire to ground . the ecm pin from cummins is onely max 20.00 you can get a kit from dodge for 150.00 and it hooks same way the onely thing more you get wth the kit is a safty switch that mounts under dash on the clutch peddal . shannon
06 dodge 3500 ,banks big hoss six gun ,smarty tnt,tst,southbend clutch ,diablo sport ,edge w attude
easymon is offline   Reply With Quote
Old 09-24-2008, 12:08 PM   #48 (permalink)
Daveman's Avatar
Why can't we simply rig up a tension cable to pull the throttle to the required RPM on a manual trans? Even something simple like a hook around the pedal should hold the RPM's up... is it only holding RPM? or is there something else electronic going on?
So what's the catch?
Daveman is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
