Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 01-28-2008, 10:57 PM   #13 (permalink)
Originally Posted by WorkhorseDiesel View Post
Rule of thumb is ten minutes max. If you're going to be out of the truck for more than 10 minutes, then it's a good idea to turn it off. If it's cold out and you have high idle enabled, then there's no problem with idling up and warming the engine. The only real problem with idling is when it's cold out and high idle IS NOT enabled. The engine cannot, at regular idle, create enough heat to warm itself if the outside temp is very low. On the newer 6.7L, idling is a big NO-NO. The DPF will not stand up to long periods of idling and will fill up pretty quick when doing so. Hope this helps.
That DPF. Everything I hear about it sucks
Looks like my 2004.5 will be my last new diesel I buy.
HardCharger is offline   Reply With Quote
Old 02-04-2008, 08:08 PM   #14 (permalink)
I have a 04 dodge and after I had my high idle turned on, dodge told me to use it if my truck was going to idleing for more than 10mins. Since we are talking about idleing i have a question, this is my first dodge always had ford but glad i switched. i have had this truck almost 1yr and when it idles i have a strong smell of oil in the cab, not burning oil smell just oil.The truck does not leak any oil. Is this smell coming out of my blow by tube? If it is, is there a trick I can do to get ride of this smell.
fmff21 is offline   Reply With Quote
Old 02-04-2008, 08:10 PM   #15 (permalink)
the smell is only when i have the fan is on in the cab.
Old 02-06-2008, 12:59 PM   #16 (permalink)
Kinda a bummer if i need to sleep in the truck and its cold out,....
John 3:16 97,4x4 12V,100 Plate, Gorend Trans, Super B Turbo, Dynomite Diesel 75 HP Injectors, timing adjusted, 3KG Spring, BHAF, ATS Ex. manifold, 4" T/B Exhaust, 3.54s,TQ Lock up Switch, Optimas, Optix Guages, Luke's Links, KDP, All work done by Browns Diesel
stevep is offline   Reply With Quote
Old 02-06-2008, 01:21 PM   #17 (permalink)
Kraig's Avatar
I took my truck into the dealer last year because of some really loud clicking/clacking noise from the engine. After a few attempts to diagnose it they read the engine computer log and found that I was idling WAAAY too much and told me I had loaded up the injectors. Oddly enough, it happened while idling during the summer with the AC on full blast to keep the dog from roasting while I went in to the grocery store for brewskis. Good information all around though since I still find myself letting it idle too long during the winter to warm up. Need to have the high idle enabled I guess-
2006 2500 QC LB 4X4 6 Speed Manual: AFE Stage II Air Intake, CFM+ intake horn, Bullet, Jacobs Systems Exhaust Brake, Diamond Eye Exhaust, n-Fab Nerf Steps, 2" Level, Toyo 295/70R17 MT's, Fold-a-Cover Tonnaeu, Amsoil BMK-21 Bypass system, and Mag-Hytec Diff Cover
Kraig is offline   Reply With Quote
Old 02-06-2008, 08:31 PM   #18 (permalink)
Ok,.. so how bout a high idle install where i can keep the EGTs at 300
would that be enough temp to not cause any problems ?
Old 02-06-2008, 08:44 PM   #19 (permalink)
TEXAS SOUTH CHAPTER VP
Jesparza300's Avatar
for cold weather, why dont yall guys plug the trucks in
my truck as the pigtail to plug it in to a regeular outlet to get the engine warm
TEXAS COAL ROLLERS SOUTH VP
07.5 dodge ram 2500 4x4 6.7 diesel
68RFE 3.73 gears all stock for now
http://www.cumminsforum.com/forum/texas/
Jesparza300 is offline   Reply With Quote
Old 02-07-2008, 01:29 PM   #20 (permalink)
Tech Specialist
WorkhorseDiesel's Avatar
stevep,
As long as you're in the 1100-1400 rpm range, you should be fine idling all you want.
2001.5 White 2500 Reg-cab • 4x4 • NV4500 • 4.10 • BHAFWALBRO GSL392Edge Juice + AttitudeVALAIR HD OFEScangauge II • 315 Cooper S/T's • Optimas • custom black grille & blue graphics • ** Diesel Fuel Treatment is here **
WorkhorseDiesel is offline   Reply With Quote
Old 02-07-2008, 08:01 PM   #21 (permalink)
Talking
stevep,
Thats good news, ill rig up a pull throttle or get a nice rock
i travel sometimes and just need to pull over and sleep... coarse its always freezing out
i dont really mind changing the oil more often either
Thanks !
steve
Old 02-21-2008, 09:28 PM   #22 (permalink)
bellyup039's Avatar
I worked midnight last night and it got down to 3degrees outside, when i got in my bran new 2008 at 7 am.
I started it at 6:45 am and it sat with the heater on for 15 min. I was keeping an ear on it as it ideled up and down all by it self.
Yes I saw that 2008 is a no no and I know that. I had to find out while it's under warranty.
so far no problems.
2008 Mega cab 6.7 SXT BADP GEN 2 4"Down Pipe, EGR Unplugged Edge Juice w/Attitude 18.4 mpg on #1 setting
bellyup039 is offline   Reply With Quote
Old 06-06-2008, 09:19 PM   #23 (permalink)
I had a 99 24v that i used for long rage towing.
I had the passengers seat and rear seat out and a bed there.
I would sleep in it for 8+ hrs every nite. Ran all day long and idled all night summer and wenter. i didnt have a high idle, Yes it cooled down a little in the cold winter nites BUT i have a little space heater that i could plug in..between me and a friend we put um...prob 200-250K miles on it like that. NEVER A PROBLEM WELL..... just 2 lift pumps and a inj. pump and tires : )
Im sure it had thousands of hrs of idleing...
Never hurt it it still runs like a top.... 580K mi little brother beats it now.
04.5 600 series CTD,4dr, 4x4,373's 5" stright pipe, gently rolled over seriously
stock for now.....
05 ctd 4DR 4X4 PARTING OUT! ( TREE MET CAB)
street-legal? is offline   Reply With Quote
Old 06-06-2008, 09:32 PM   #24 (permalink)
csixer's Avatar
you or should i say 2nd gens are a little more forgiving to ideling. but im sure you had some diluted oil. but not only on a 3rd gen will you dilute your oil but youll coke up and fubar up the 3800 dollar set of injectors. but all is well
06 RAM 2500 QC SB 4X4,auto crapic, smart s06, airaid intake w/ amsoil filter, silverline exhaust,fluiddampner, tinted windows, ful gauges on the piller.
csixer is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
